need help...running bad
Old Dec 22, 2006 | 08:43 PM
v-takracing!'s Avatar
Default need help...running bad
Alright basiclly the situtation is: the idle is alternating from i have it now to about 800 and it goes to about 1700. It starts up it is now smoking white (oil) and continues to smoke while its running. It feels like it is bogging down but if i get on it it feels perfectly normal. i hooked a vaccum gauge up to it and it keeps jumping between 14-19 psi. My haynes book is leading me to believe either: rings, burnt valve, or worn valve guides. Now being that the motor has roughly 15,000 miles on it...how could this be? Is it a sensor that i am just ignorant to being i am not a honda guy or is it one of the big things mentioned? thanks for the help guys!
Old Dec 22, 2006 | 08:52 PM
MrAngry's Avatar
Default Re: need help...running bad (v-takracing!)
did you check the tps and map sensor voltages yet?
Old Dec 22, 2006 | 09:51 PM
Sumslapper's Avatar
Year 3030
Default Re: need help...running bad (MrAngry)
white = burning lots of coolant. blow a headgasket recently? when mine was blown it had a whacky idle
Old Dec 22, 2006 | 10:10 PM
Fat Chick Magnet's Avatar
blue is smoke.
Old Dec 22, 2006 | 10:11 PM
Default Re: need help...running bad (sumslapper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sumslapper &raquo;</TD></TR><TR><TD CLASS="quote">white = burning lots of coolant.</TD></TR></TABLE>
sometimes if your lucky its your valve seals. for some reason i did valve adjusment and changed all my valve seals and it stopped blowing out white smoke now all you see is dark/black smoke from tip of exhaust.
Old Dec 23, 2006 | 08:18 PM
i have nto checked anyhting yet..all i know thus far its throwing a code and running like absolute ****. I was under the impression white smoke is oil...thank you for the correction.
Old Dec 23, 2006 | 09:13 PM
jikespingleton's Avatar
Default Re: (v-takracing!)
have u checked wat code or codes its throwin at you?
cloudconnected85
Sep 23, 2008 09:15 PM
SimplyTron
Oct 16, 2006 02:24 PM
SOHCmaster
May 28, 2005 09:43 PM
GOLDBERG
Apr 24, 2003 02:09 AM
Toda Party
Aug 5, 2001 02:07 PM
