Need help please answer b18c5
Old Feb 10, 2009 | 06:47 AM
grac97's Avatar
Default Need help please answer b18c5
I have a 01 type r swap that i recently put in the car about 10 months ago, everything went good until i had a problem with the tps. well i got a new tps and put it on and it erased the code that it threw in the car. but now every once in a while, when im ridin the car ill have it on 2nd gear just cruising at 2500 rpms when i switch gears to 3rd and then rpms drop down to like 2000 rpms and then step on the gas the car like hesitates doesnt go anywhere and then it goes but give you a hard jerk everytime you hit the gas on low rpms. what could it be. could it be the fuel pump, or my distributer, cause i have a ls distributer on my type r head, could that be the porblem. please guys let me know, what you think it is.
Old Feb 10, 2009 | 07:00 AM
j_bizach's Avatar
Default Re: Need help please answer b18c5
first id test ur tps to make sure its callibrated rite. Then id run a quick test on ur fuel pump to make sure no problems ther (Since u can test both these and completely iliminate them as a problem) then id look into ur ignition.
Old Feb 10, 2009 | 07:10 AM
Shawn C's Avatar
In The Garage
ok, first, like dude above said, did you calibrate the new tps? and i guess you cut a tab or two on your distributor... is it totally secured? did you jump the service connector under the dash and set the timing to 16 deg?
Old Feb 10, 2009 | 07:15 AM
grac97's Avatar
no how would i do that.
Old Feb 10, 2009 | 08:44 AM
mouab18c1's Avatar
do what? calibrate the tps? or check your timing?
Old Feb 10, 2009 | 11:09 AM
scbmx87's Avatar
I didn't think an LS dizzy would bolt up to a VTEC head properly?
IIRC i tried it a while back and only one bolt would line up.
GPC91
Sep 9, 2012 02:13 PM
hville_red_eg6
Jun 23, 2011 03:54 PM
grac97
Feb 10, 2009 07:02 AM
Malgerus
Aug 8, 2002 11:19 AM
