Need Help!! OBD2 To OB1!! Dc2
I have a dc2 ls. Recently just bought me a obd2 to ob1 harness.
Was wondering if i can buy a 92-93 ls ecu to connect it to my car. Or i can only buy a p28 ecu??
I was wondering... is that a good idea swapping a obd2 for obd1 performance wise? i have a '96 gsr and i've herd that was the 1st year they put in the obd2 and that the obd1 was better in '95 and older - if i did swap what kind of changes should i expect?.. im new to all the computering involved in tuning - Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRStreetRacer »</TD></TR><TR><TD CLASS="quote">I was wondering... is that a good idea swapping a obd2 for obd1 performance wise? i have a '96 gsr and i've herd that was the 1st year they put in the obd2 and that the obd1 was better in '95 and older - if i did swap what kind of changes should i expect?.. im new to all the computering involved in tuning - Thanks</TD></TR></TABLE>
If you're just planning on swapping in a stock OBD-1 ECU, it certainly won't be worth the cost or effort, and there won't be any real performance gain to speak of. Generally, converting to OBD-1 is done in order to run a tunable setup such as Uberdata or Hondata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
If you're just planning on swapping in a stock OBD-1 ECU, it certainly won't be worth the cost or effort, and there won't be any real performance gain to speak of. Generally, converting to OBD-1 is done in order to run a tunable setup such as Uberdata or Hondata. </TD></TR></TABLE>
Yah thats what i was considering - i've been on the hondata website for about 2 hrs learning what i can. I haven't found anywhere on the website where it says obd2 - so i figured i could go to a obd1 and grab a s200 computer and start tuning..
If i were to get a obd1 could i just grab it out of an older teg from a junkyard? because theres about 1000 junkyards in my area, would it just be a matter of finding the right year? (not taking into consideration the model)
it will help a little. that's all i know... my 97 ls knock sensor is ******* everything up. i have a turbo set up, **** is slowing me down. check light engine on, i cant do anything. thats why im doing a convert to take out that lagg.
Ill sell you my p28 ecu chiped...look down at my sign
SINCE you do have a turbo set up, you definately should go with an obd 1 ecu. You can actually use any 1992-95 civic/integra ecu, but since you have an LS, search for obd 1 92-93 pr4 ecu or 94-95 p75 ecu. Be sure to look into uberdata or hondata since turbo's usually need extensive tuning.
BTW: if you dont have a vtec motor, then YOU DONT NEED a p28 ecu! You need a non vtec LS ecu
im gonna go b20 vtec turbo.... but for rite now im just gonna chill with my ls turbo thats why im looking for a obd1 ecu.
TurboTegB
Dec 18, 2004 01:57 AM
