Need Help with my reverse
Old May 4, 2008 | 05:55 PM
a_larcher's Avatar
Default Need Help with my reverse
1994 acura Integra, my reverse kicks out when I fully take my foot off the clutch. The transmission is full of oil. I am woundering if there is an adustment and where is it(if there is one) what can I do?
Old May 4, 2008 | 07:30 PM
Blahblah718293's Avatar
Default Re: Need Help with my reverse (a_larcher)
im assuming this is a 5 speed? make sure the linkage isnt bent, other than that it can only be inside the transmission.
Old May 5, 2008 | 05:08 AM
a_larcher's Avatar
Default Re: Need Help with my reverse (Blahblah718293)
Ya it's a five speed, but i have been told that there is a way to adjust the reverse from the outside... It;s almost like it doesent want to go all the way in like it use to.
your answer is greatly needed. thanks
Old May 5, 2008 | 08:31 AM
IN VTEC's Avatar
The reverse actuation mechanism is integrated into the forward gears shifting mechansim. You can't tweak it independently.
My guess is that the synchro sleeve and synchro spring are damaged and reverse isn't engaging all the way.
Old May 5, 2008 | 01:44 PM
a_larcher's Avatar
Default Re: Need Help with my reverse (IN VTEC)
That sound like the probleme, the gear wont go as far as it used to. any suggestion on fixing it? thanks
Old May 5, 2008 | 03:43 PM
IN VTEC's Avatar
Replace the 5th-reverse synchro set.
Old May 7, 2008 | 05:56 PM
a_larcher's Avatar
Hmm! So i have to take out the transmission.. Now thats problomatic.
Happy Gilmore
Sep 23, 2008 07:29 PM
BojanB16A
Apr 2, 2007 11:20 PM
20ls01
Mar 26, 2007 05:48 PM
B and B
19
Oct 29, 2005 09:54 PM
Civichatch2k
Jan 11, 2004 08:04 PM
