NEED HELP!! Manual to Auto Conversion Question..
Old Jul 2, 2004 | 07:57 PM
92HB_HB's Avatar
Default NEED HELP!! Manual to Auto Conversion Question..
a friend of mine is taking a Manual 90 integra and converting it to an Automatic.. He's pretty much has the swap done and it drives foward and in reverse.. Its for his daughter to drive...
THe problem that he's having is that the transmission won't go into the higher gears like an automatic should when driving.. I'm pretty sure its a wiring issue, b/w the trans, speed sensor and ECU or something...
Does anyone know how to make this swap work properly?? I've never done such a swap b4, so i would be clueless on where to begin..
THanks in advance..
Old Jul 2, 2004 | 09:17 PM
JiggyKooAndy's Avatar
Default Re: NEED HELP!! Manual to Auto Conversion Question.. (92HB_HB)
Wow, I've actually never seen this swap done before. Hope you get some help; but unfortunately, there's only a handfull of auto's on here, and even less of them have taken the tranny out...if any. Good Luck
Old Jul 2, 2004 | 11:12 PM
honura's Avatar
Default Re: NEED HELP!! Manual to Auto Conversion Question.. (JiggyKooAndy)
Well the only thing I could think of is tell him to leave the tranny wire that hooks up to the TB kinda loose. Also check to see if he changed the ecu, also Maybe the solinoids. The ECU tells the tranny solinoids to changed gears or something like that. goodluck man.
Old Jul 3, 2004 | 05:20 AM
92HB_HB's Avatar
Default Re: NEED HELP!! Manual to Auto Conversion Question.. (honura)
he's running the proper ECU and i'm pretty sure he's done the tranny oil as well.. THe selonoids may be the answer.. where are they located?
Old Jul 3, 2004 | 05:37 AM
slomob18b's Avatar
What kinda condition is the auto tranny in? I remember in my friends old 91 integra, the tranny took a while to shift into the next gear. He had to drive it for about 30 minutes before it began to function properly.
ferio-ichi3
27
Apr 16, 2013 12:48 PM
tyler100
12
Jul 15, 2008 08:53 AM
KaoSyN
Dec 15, 2005 11:03 PM
5lugSlug
Jul 6, 2005 08:11 PM
92HB_HB
Jul 2, 2004 08:36 PM
