Need help! Gauges do not work
My gauges do not work for some reason what could it be? it doesn't tell me how much gas I have or speed or RPM not Even Temp but They do light up and the turn signal indicator works but thats it. Help anyone?
sounds like a fuse or somethin. theres a 15 amp wire that goes to the fuse box i believe under the dash but it could be the under hood box and that runs most of the cluster. see if thats bad. if not you may have loose connections or at worst ab bad ecu. never heard of a cluster going out though like yours has. but its still possible you cluster is bad. tell us more about your car so we can post more. the 15 amp wire is for a car i just worked on and that was the issue. your electrical circuit may be a little different
Well its a 94 integra GS sedan I just bought it 2 days ago the gauges didnt work when I bout it the guy said he thinks its a fuse but if it was a fuse why it still light up and plus I dont know where the fuse is or which fuse it is.
You sure because i have checked every fuse and I took my cluster out and the screen is cracked what if the guy i bought it from roled the miles back on purpose and didnt tell me and that messed up the whole cluster? is that possible
civicsiboosted
Sep 26, 2002 09:30 AM
