Need help with gauges
Ok i have them wired into the bay and all secured in the car but i was wondering if i have to use the adapter things they give u or if i can jus use the stock ones in the motor already and jus splice the gauge wires 2 them and get the readings on the gauges or do i need the stuff they give u i would think just splicing would b fine but wanna get a definate answer b4 i mess it up, n cause when i was putting the water temp one in it broke off in the block and now i have no way 2 no if im runnin hot or not ill fix that n then ill have 2 use the stock one n jus splice it so i hope it works but i need a defenite answer. and also if it will b ok and can splice and use the stock ones which one is the oil pressure if its the one wit two wires is one jus a ground n splice it into a right wire or do i have 2 replace that one i jus need the oil temp n oil pressure jus give me a detailed help of connecting and which is which for the oil pressure and oil temp thank u so much sorry for the long novel lol but i would appreciate it cause it looks dumb wit gauges that dont work only light up
http://www.facebook.com/photo.php?pi...00001113225089
http://www.facebook.com/photo.php?pi...13846291995811
http://www.facebook.com/photo.php?pi...13846295329144
this wont let u all go into my facebook account will it u cant access anything jus look at the pic right i dont think it will do it as long as im logged out just wanna make sure if im logged in u cant do nuttin cause im on there alot
not sure how all this stuff works yet jus messin wit it but copy n paste i think i did a pretty good job jus check it out
oh ok nice well i still need to no wat to do theres three sensors beside the oil filter on with a green plug and 2 wires coming off wat is that, and then there is one with one wire what is that one im thinkin thats the oil temp, and then there is one with two wires and i think that is the oil pressure, and i was wondering if i can take my wires from the gauges and just splice them in the stock sensor things by the filter instead of goin through the hastle of putting the ones in they gave u
ok so i did some serious searching for the past forever n found that there are three sensors to the left of the oil filter the one on the top farthest up is the ECT the one to the farthest left is for the oil temp and the one on the bottom is for the oil pressure, so for anyone who needs it in future reference no thanx to search on honda tech it sux it gives u a million answers 2 one word they need to fix it some how i had to use bing forever n found some other honda site where some dood had a whole right up about everything it was perfect stupid honda tech
lancerkid06
Jan 7, 2008 07:17 PM
DC2_Integra
Feb 22, 2004 09:19 AM
civicmandx94
Feb 10, 2003 10:48 AM
