Need help on fuel pump install
Old Sep 24, 2003 | 06:39 AM
turboZChatch's Avatar
Default Need help on fuel pump install
Ok my friend has a 94 gs-r and just bought the new holley forced induction in tank pump my question is can I acess it from under the seat or do I have to drop the tank?
Old Sep 24, 2003 | 07:03 AM
4dGSR at work's Avatar
Default Re: Need help on fuel pump install (turboZChatch)
its easy..
hardest part is lining up the bolt to get the seat back down... dont drop it.
ok careful to not strip the lil bolts.... and its easier w/ less gas in the car.
another thing...
bring a towel to hold the damp old pump w/.
and another thing...
open the windows and do most of the work out side of the car if you can.
Old Sep 24, 2003 | 07:56 AM
Echo7847's Avatar
Default Re: Need help on fuel pump install (4dGSR at work)
Not hard @ all. You can access the metal cover underneath the rear seat, and its the painfully obvious shiny metal lookin thing. Theres a couple bolts around the edges of it, I think they were 12mm ones, then pop the top off and out comes the fuel pump attached to the bottom. Then it's just a plug and play affair after that. If you dont wanna get gas on the floor try de-pressurizing the fuel lines.
Good Luck
Old Sep 24, 2003 | 08:16 AM
Default Re: Need help on fuel pump install (Echo7847)
Thanks for the replys guys I am gonna do it now I will let you know how it comes out
Old Sep 24, 2003 | 10:50 AM
Fuel pump is in and working mint the car woke up big time thanks guys
Old Sep 25, 2003 | 04:03 AM
awesome...way to go. Now help out the next man!!!!
KARMA!
z1gary
Mar 24, 2013 02:22 PM
hitvtecgetloud09
Aug 31, 2004 05:45 PM
ABTDer
10
Nov 3, 2003 12:09 PM
B20LS-T
Aug 16, 2003 10:56 PM
Vtecless212
Mar 7, 2003 02:03 PM
