Need help with distributor wiring for testing
Have a code 8 for my 92 integra ls. Research says to replace the distributor in order to replace the TDC sensor build in it. I want to test the TDC wiring before I spend $200 bucks but can’t figure out which one(s) to test.
7 wire connector from the distributor to the wiring harness
The 7 pins for the distributor not the wiring harness
Connector from wiring harness to the distributor plug
2 wire 2 pin connector on the distributor. The bottom connector is from the wiring harness
RACEPAK
08-28-2009 11:29 AM
