need help asap
Old Aug 23, 2009 | 10:00 PM
acuralovar's Avatar
Default need help asap
i just removed my old motor and put in a new one..i didnt touch any of the wiring just unplugged them and then replugged them into this motor etc. and soon as i put on the termials to the battery my thermostat housing sensor was smoking then i seen a instant smoke come from my cluster also ..i pulled off the termials quickly to seee wat was goin on ..then i reconnected them and all the lights on my dash were on ..and wen i put my turn signal on it makes this loud noise and my temp guage needle jumps ...could anyone help me out...the car is a 92 integra
Old Aug 24, 2009 | 11:12 AM
Puma909's Avatar
Default Re: need help asap
BUMP!
Old Aug 25, 2009 | 10:50 AM
sjbmx's Avatar
sounds like you shorted something out. thats weird that it made a noise tho.
Old Aug 25, 2009 | 11:17 AM
GSaura's Avatar
Did you get the terminals backwards? You have the chassis ground and starter power hooked up to the right place in the fusebox?
Old Aug 25, 2009 | 11:29 AM
stocker2shocker91's Avatar
I requested a short story for a title.
sounds like that might be the issue hopefully fuses gave way instead of wires
Old Aug 25, 2009 | 01:55 PM
nsxtasy's Avatar
H-T Order of Merit
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Old Aug 25, 2009 | 04:36 PM
acuralovar's Avatar
no i didnt ive always have the postive termial hooked up , and i just always plug and unplug the negative one..and as far as for the ground yes its hooked up and the starter is hooked up..i didnt mess around with any wires wen i ddid the swap and just put them to the side ....and as far is for that noise its always doin it everytime i put on the blinker..everrythikng works as far as for lights ..i think i shorted something out with that connector at the thermostat housing. since i unplugged it everything seems fine besides the cluster ...im gna start up the car tomorow and see wat happens
EG-Coupe
Dec 11, 2009 01:30 PM
CHAMPwhteEK
Aug 7, 2009 08:24 PM
callmechad
24
May 9, 2009 03:52 AM
slammedz6ef
Dec 4, 2007 05:39 AM
VtecGsr95
Jul 11, 2006 07:53 AM
