HELP PLEASE ASAP
Old Feb 12, 2008 | 07:11 PM
matmcg's Avatar
Default HELP PLEASE ASAP
So this is what happend
Locked keys in car while car was on
Had to kill engine because I had no gas
Pulled out spark plug
So then when i got back into my car I tried to start it by putting the plug back in
wouldnt start just keeps turning over
all this time it was snowing and my hands felt like they were going to fall off
HELP ASAP WHAT COULD IT BE
Old Feb 12, 2008 | 07:18 PM
jdmDAic's Avatar
Default Re: HELP PLEASE ASAP (matmcg)
make sure all the wires are push in all the way?
did you mess with anything else?
...it does have gas right? lol.. just asking?
Old Feb 12, 2008 | 07:22 PM
matmcg's Avatar
Default Re: HELP PLEASE ASAP (jdmDAic)
the things i messed were was the battery and the spark plugs
I basically just took the battery off and put it back on
Took 2 spark plugs out and put them back in
even tried boosting it but it just keeps trying to start
maybe some snow flakes got in the spark plugs :S
and yes i have gas
Old Feb 12, 2008 | 07:31 PM
matmcg's Avatar
BUMP TO GO TO WORK TOMOROW
Old Feb 12, 2008 | 07:49 PM
matmcg's Avatar
BUMPO!
Old Feb 12, 2008 | 07:50 PM
goota's Avatar
try resetting your ecu?
Old Feb 12, 2008 | 07:55 PM
matmcg's Avatar
Okay how do I do that?
Is there any way I can possibly screw up?
and how does this fix it so I know the theory behind it
Old Feb 12, 2008 | 08:10 PM
fergy016's Avatar
Default Re: (matmcg)
What have you done so far?
Do you have:
Air(is the air filter dry and clean?)
Fuel(is the fuel filter clogged/fuel pump making the wir sound when the key is first turned on)
Spark(Are the spark plugs making spark when the car is turning over?)
If all these are good you should have ignition and the engine should start.
Good luck.
Old Feb 12, 2008 | 08:17 PM
matmcg's Avatar
Default Re: (fergy016)
the air filter maybe got a little bit of snow on it
oil filter just changed
dont know how to tell if the spark plugs are making spark
the car was working until i took off the battery and spark plugs
Old Feb 13, 2008 | 03:27 AM
matmcg's Avatar
HELP PLEASE I WANT TO GO TO WORK TODAY
Old Feb 13, 2008 | 03:51 AM
jhammond_82's Avatar
Reject Papi
why wouldn't you have just disconnected the battery? i mean if you had the hood clearance to remove a spark plug, why not a battery terminal?
Old Feb 13, 2008 | 05:58 AM
matmcg's Avatar
Default Re: (jhammond_82)
I did disconnect the battery but the engine continued to run so i just pulled the spark plug out
some one please help
Old Feb 13, 2008 | 06:07 AM
Reject Papi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">I did disconnect the battery but the engine continued to run</TD></TR></TABLE> *scratches head* huh? you can see if the plugs are making sparks by getting someone to turn the engine over while you have the plug out of the hole. maybe something coincedently happened when you did that. ???
Old Feb 13, 2008 | 06:09 AM
matmcg's Avatar
Do you knwo the possible problems that could have happend?
is it possible that the spark plugs are dead what could possibly be wrong I am puzzled. maybe a blown fuse?
dotn know where to start its freezing out side
Old Feb 13, 2008 | 06:33 AM
matmcg's Avatar
BUMP
Old Feb 13, 2008 | 07:56 AM
matmcg's Avatar
BUMP!!
Old Feb 13, 2008 | 09:15 AM
all-mtr-teg's Avatar
You may have damaged your ignition coil when you removed the spark plug wires. Also check your fuses, back up fuse, ecu fuse etc.
95sirek4
Sep 2, 2011 07:35 PM
em1_racer
Apr 24, 2008 04:26 PM
rewerbcrx
24
Mar 11, 2006 06:40 AM
Trbospnkr
Dec 29, 2003 09:46 AM
turbocivicef
May 8, 2003 12:11 PM
