need help???
Old Mar 9, 2004 | 07:22 PM
mini-v-si's Avatar
Default need help???
my motor is a obd2 motor, previous I had a obd1 distributor installed on my car and it ran like ****, now I got a obd2 distributor, the car wont start, it sounded like it was going to but it wont, it only crank. what could it be????
Old Mar 9, 2004 | 07:27 PM
mr.beeks's Avatar
Default Re: need help??? (hx007)
that is a very vague explenation and title
pls supply year of car and ecu you are using
Old Mar 9, 2004 | 08:09 PM
mini-v-si's Avatar
Default Re: need help??? (mr.beeks)
I have a 94 gsr teg recently blew the motor, now bought a 96 gsr and got it in. previously had problem with obd2 distributor and got the obd1 lying around and decided to put it on and it worked but ran like ****, now got the obd2 on but it wont start it cranks, sounding like it was going to start but it wont, I'm using a p28 with skunk 2 chip. what should I consider looking at???what are some of the problems I will have with this obd2 into obd1???
thanks in advance.
Old Mar 9, 2004 | 08:14 PM
mr.beeks's Avatar
it looks like you did not swap some sensors need
all you had to do is while both engines are out
look and swap sensors that are needed
maybe one of the vacums is connected wrong as well
but since you are using a chipped p28 stick to the obd1 distributor..
check all vacums and compare old block to new block..
Old Mar 9, 2004 | 09:24 PM
Kendall's Avatar
You will have to run the OBD-1 ECU to run off of the P28. I know there are other issues, but I'm not sure as to exactly what they are. Search is your friend.
Old Mar 10, 2004 | 06:00 AM
mini-v-si's Avatar
thanks let me try. get back to you.
Bhamm95LS
Dec 2, 2017 08:02 PM
91tegrals
Jul 30, 2007 11:21 AM
Nameless RB26
Oct 4, 2004 03:47 PM
Kid1320
Jan 18, 2003 09:14 PM
