IN NEED OF HELP!!!!!!!
Old Sep 5, 2003 | 05:08 PM
trutuner's Avatar
Default IN NEED OF HELP!!!!!!!
Hey guys i was doing the normal install of my head everything was working just fine then my power wire (the yellow one), touched my head unit and blew something, this is where I'm stuck, i went through all the fuses and no luck, please help me out guy!..Also the clock wont work at all if this helps....everything else is perfect I mean all other lights, accesories, cig lighter, etc! thanks -Roger
Old Sep 5, 2003 | 05:13 PM
mr.beeks's Avatar
Default Re: IN NEED OF HELP!!!!!!! (trutuner)
have you checked fuses on the engine bay?
Old Sep 5, 2003 | 05:30 PM
tegmech's Avatar
get a voltmeter and find out where its not getting power. Is it before the fuse box or after?
Old Sep 5, 2003 | 05:35 PM
trutuner's Avatar
ok thanks guys any other tips.-Roger
Old Sep 5, 2003 | 07:03 PM
trutuner's Avatar
Default Re: (trutuner)
up again!...-Roger
Old Sep 5, 2003 | 10:57 PM
FastSS's Avatar
most likely: underhood fuse box, fuse marked "back-up" or something like that...
Old Sep 6, 2003 | 03:16 AM
poison's Avatar
Ya, first of all. Check ALL fuses. This includes the ACG (Ignition) fuse in the underdash fuse panel, as well as the PGM-FI (ECU) and ECU back up fuse which is located in the underhood fuse box.
Make sure also they are the correct amperage. If those are bad, replace 'em. If not, then troubleshooting will go further.
Does your fuel pump prime at all?
With the key in the ON position, does the CEL come on and go off after two seconds?
keep us posted.
Old Sep 7, 2003 | 05:46 AM
trutuner's Avatar
Default Re: (FastSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastSS &raquo;</TD></TR><TR><TD CLASS="quote">most likely: underhood fuse box, fuse marked "back-up" or something like that...</TD></TR></TABLE>
This was it...thanks so much guys i was really scaredfor a minute there!....my new head unit (deh-840) is great!....-Roger
thomaswjparker
Mar 24, 2014 06:59 AM
DSRxSALSA
Oct 24, 2008 12:47 PM
dylokjai
Dec 20, 2006 11:12 AM
2LoW4FaThOeS
Aug 4, 2002 10:40 PM
