Need help with t-stat ground
Old 11-21-2017, 04:03 PM
rlyn09's Avatar
Default Need help with t-stat ground
I have a 1996 civic and the connecting pipe rusted out so we had to replace it also the thermostat housing. We noticed a ground with 3 wires connecting to it but we didnt know it at that time so we cut it. The new housing that we got didnt have any grounding terminal so we didnt put it back yet. Then we had another problem which was crank no start with CEL light on. We tried grounding those 3 wires together and spliced it into a single wire then to ground and the car started. But the CEL light is still solid. Also when i turn it to ON(II) position, the cel light will flicker just as the main relay clicks the stays solid again. I tried jumping the service connector hoping to get some codes but it still solid. Please help me i’m getting confused! Thanks!
Old 11-22-2017, 05:55 AM
mk378's Avatar
Default Re: Need help with t-stat ground
Those wires ground most of the ECU system, so they are important. Sometimes the thermostat cover and/or housing is not solidly grounded to the engine. With the key on, there should be less than 0.1 volts from the wires to the battery (-) post. If there is a significant voltage, find out where the problem in the grounding system is by measuring from each point, moving closer to the battery.
Old 11-22-2017, 10:49 PM
rlyn09's Avatar
Car is running fine now. But the only problem is now i got a solid CEL light. Before it was not there when i was using the old thermostat housing. Any ideas where it is coming from? Is a bad ground causing this?
Old 11-24-2017, 01:45 AM
adamhunsicker's Avatar
Without knowing the code it's throwing any responses here will be pure guesswork. It's a '96 so it's OBD-II, take it to your local parts store and get the codes read (most Autozones and the like will do it for free) and report back.
Track Beast
12-05-2010 01:04 PM
jdmouttheass
10-09-2010 07:32 PM
sittin_sideways
11-01-2007 04:29 PM
.kyle
11
06-27-2006 03:10 PM
Quick Reply: Need help with t-stat ground
