Need help!!
Old Feb 9, 2007 | 03:02 PM
ehhhdc2's Avatar
* B A N N E D *
Default Need help!!
I was changing my coilovers and I noticed the passenger side -tie rod boot was leaking out grease or something anyone know what's wrong or what this is? I'm not losing any power steering fluid.
Old Feb 9, 2007 | 03:03 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: Need help!! (ehhhdc2)
Red X's
Old Feb 9, 2007 | 03:05 PM
ehhhdc2's Avatar
* B A N N E D *
Default Re: Need help!! (SlammedDC2)
fixed
Old Feb 9, 2007 | 03:31 PM
Micha's Avatar
FAILWGN
Change your boot. They are bitch though.
Old Feb 9, 2007 | 03:45 PM
DS002's Avatar
Banned
Default Re: Need help!! (Blu99teg)
Thats your bellows boot , even just changing the boot may not stop the problem . Your better of changing out the whole unit . Do some junkyard searching and see what you can find
Old Feb 9, 2007 | 05:01 PM
SoTexDC2's Avatar
If your not loosing Power Steering fluid, it could be oil leaking from somewhere else. Or a sloppy change.
Old Feb 9, 2007 | 05:08 PM
DS002's Avatar
Banned
Default Re: (SoTexDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoTexDC2 &raquo;</TD></TR><TR><TD CLASS="quote">If your not loosing Power Steering fluid, it could be oil leaking from somewhere else. Or a sloppy change.</TD></TR></TABLE>
Yea if oil looks like axle grease sure , its not power steering fluid and it isnt oil . Its grease , at the minimum attempt at changing the boot
Old Feb 10, 2007 | 07:45 AM
ehhhdc2's Avatar
* B A N N E D *
Default Re: (DS002)
so i should start by changing the boot and go from there?
for SoTexDC2:
what did you mean by sloppy change? sloppy oil change?
Old Feb 16, 2007 | 10:19 AM
SoTexDC2's Avatar
Default Re: (ehhhdc2)
Sorry, I didn't expand the pictures the first time. I was thinking you/somebody might have spilled oil when the filter was changed.
DS002 is right, its clearly grease. Try changing the boot, if that doesn't help you might have to replace the entire unit.
Old Feb 16, 2007 | 12:59 PM
knomexx's Avatar
looks to me like your p/s rack is leaking. it might not be leaking enough that you notice a fluid drop.
Old Feb 16, 2007 | 01:09 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (knomexx)
I'm pretty sure those boots do NOT hold in power steering fluid. The fluid is more internal to the rack itself. I replaced my outer tie rods and the boots about 15 months ago and nothing leaked out when I removed my old boots.
But I will agree, changing those rack boots is a royal PITA with the engine still in the car. I would probably go ahead and get new outer tie rods ($30/side from Baranco) and put on new boots, then get the car aligned.
Old Feb 16, 2007 | 03:30 PM
knomexx's Avatar
Default Re: (PatrickGSR94)
That boot in the picture is only a dust boot. It is not ment to hold any power steering fluid. There is a seal behind that boot that does hold p/s fluid inside the rack. If that seal is leaking, it will collect in the boot and start to leak out. to see if this is the case you dont have to replace the boot. Only remove the clamp holding the boot to the rack. Slide the boot away from the rack and see if there is fluid inside it. No need to remove the tie rod. Or just try squeezing the boot. If there is no fluid in the boot your problem lies somewhere besides the rack.
Old Feb 17, 2007 | 01:30 PM
NBPdEeCeE's Avatar
* B A N N E D *
Having the same problem
Old Feb 17, 2007 | 05:30 PM
ehhhdc2's Avatar
* B A N N E D *
Default Re: (ViSioNxBoY)
lol
forevermemorabl
14
Mar 27, 2014 04:14 PM
nello a.
Apr 30, 2010 05:05 PM
AcuraTilIDie
Mar 18, 2008 08:20 PM
Cuong-nutz
Apr 19, 2005 10:46 AM
nek0
Sep 25, 2003 08:06 AM
