NEED HELP!!!
Old Aug 7, 2005 | 10:02 PM
desert_trix's Avatar
Default NEED HELP!!!
have a 91 ls that is overheating already changed thermostat, radiator and cap, a/c fan relay and the car still overheats when a/c is on and at a stop dont know what else to do pls help this is gettin irritating replacing things thanks in advance
Old Aug 7, 2005 | 10:15 PM
egerdahl's Avatar
Default Re: NEED HELP!!! (desert_trix)
Overheating is always irritating like that...all I can say is put some power directly to your cooling fan to make sure it actually works. Otherwise it may be your water pump...when was the last time it was changed? Does coolant disappear on you, leak on the ground or does the engine consume it somehow?? Hopefully not a headgasket or cracked head. Is the oil milky at all? Did it ever overheat real bad?
Old Aug 7, 2005 | 10:31 PM
no engine never overheated really bad and oil just changed no fluid dissappearing and fan worked when power straight to battery so maybe it might be a fan swictch hopefully no head gasket or cracked head
Old Aug 7, 2005 | 11:18 PM
DAguyLS's Avatar
take a look at your water pump, you won't necessarily <sp? see any fluid leaking cause water pumps have a weep hole. the fluid will basically evaporate.
but look at your water pump and see if it's all covered in gunk *dirt and coolant*
Old Aug 7, 2005 | 11:37 PM
ah ic well ill do what i can and check it out this weekend thanks
Old Aug 9, 2005 | 12:37 AM
bump any more ideas of what it could be
Old Aug 9, 2005 | 01:16 AM
dynamyks's Avatar
Its probably just the water pump, but the same thing was happening to my friends car, it kept overheating and it got to the point where steam was coming from his exhaust and his oil was milky, turned out to be a blown head gasket, is there steam coming out of your exhaust?...if so then your head gasket is gone
Old Aug 9, 2005 | 01:40 AM
Default Re: NEED HELP!!! (dynamyks)
nope no steam just car overheating at stops after driving for awhile and oil is not even milky just changed like a week or two ago
88HATCH(:
17
Mar 27, 2012 07:04 AM
jlowellintegra
Jun 25, 2011 12:31 PM
54
Nov 20, 2008 12:39 AM
2camsaam
Sep 25, 2004 02:13 PM
froggysquasher
Jun 19, 2004 12:00 PM
