My MAP sensor is not in the right spot?????
Old Sep 1, 2010 | 11:38 AM
moekhanafer's Avatar
Default My MAP sensor is not in the right spot?????
I recently got an edelbrock 65mm Throttle body for my 92 GSR. I swapped the original b17 with the b18c (2000 GSR).
But when i went to install it, i noticed that the top of the throttle body that i bought has a spot where the MAP sensor goes. But the original MAP sensor for the B17 is so far from the throttle body. It is located near the top corner of the firewall area (passenger side).
I tried to see if i can just bring the wires closer but so i can just "pull" it towards the new throttle body, but the wires are too short.
Please help
Cheers
Old Sep 1, 2010 | 11:43 AM
Spawne32's Avatar
Default Re: My MAP sensor is not in the right spot?????
gotta extend the harness
Old Sep 1, 2010 | 03:56 PM
thanks for the reply Spawne32
is it ok to simply cut the wires and connect new wires to them ??
Old Sep 1, 2010 | 06:17 PM
HondaPartsHero's Avatar
Technical Hero
yeah, its best to solder but you can butt connect if you have too
Old Sep 1, 2010 | 06:58 PM
Spawne32's Avatar
yep, standard issue rewiring, i had to do it to multiple connections on my harness
motrayEG6
Oct 21, 2011 02:00 PM
moemoney
Sep 7, 2011 10:33 AM
moemoney
Aug 25, 2011 12:19 AM
atarigamer01
Jul 1, 2008 07:29 AM
