----- My Kswap, wire tuck, circut/drag track build of pepper My 1999 MR Integra-----
Old 01-21-2014, 07:33 AM
  #51
$MIKE$'s Avatar
Default Re: ----- My Kswap, wire tuck, circut/drag track build of pepper My 1999 MR Integra--
Nice work
Old 01-22-2014, 03:49 PM
  #52
HondaTom87's Avatar
awesome work so far
did you send your front lca's out or did you purchase new ones from hardrace?
Old 01-23-2014, 07:55 AM
  #53
$MIKE$'s Avatar
^ hardrace sells the complete set.
Old 01-23-2014, 03:12 PM
  #54
dc_jdm_dreams's Avatar
^^^^^^^^^^ I bought new ones from Hardrace. After ordering and receiving A energy suspension Front LCA bushing kit I realized it was easier and cheaper to buy the Hardrace LCA's. The quotes I got around town to press bushings out/and in was outrageous and my press does not have die's small enough for the work and I dont have some old junk sockets laying around.
Old 01-23-2014, 03:30 PM
  #55
Originally Posted by $MIKE$
In fort leonard wood now moving to bragg soon.
Must be nice at bliss with a decent import scene and some local parts available
There isn't **** here but muscle cars.
The import scene is Bliss is far from decent. Crappy civic's with trown together Ls/Vtecs are about all you get out here. Oh and your occasional Douche solidiers with EVO's, Z's, and WRX's. Its quite sad out here No local speed shop does quality work here and finding a good tuner is near impossible. Thats going to be fun when the time comes for a tune.
Old 02-02-2014, 11:33 PM
  #56
albertoG87's Avatar
Old 02-22-2014, 10:42 PM
  #57
Finally get some time to post what I have gotten done on my build. this is what we got so far to add.
[IMG][/IMG]
Putting the stainless steel intake studs on
[IMG][/IMG]
The head apart with the BeeHive valve springs and Ferrea flat valves.
[IMG][/IMG]
Small details wrinkled black on my V-Tech solenoid heat shield.
[IMG][/IMG]
Putting the oil pan on with the new hardware and adding a Gasket to it.
[IMG][/IMG]
My Rocker Assembly. I used zip-ties to hold everything together. Worked very well.
[IMG][/IMG]
New K24 OEM Head gasket and ARP head studs.
[IMG][/IMG]
The heads on and now mounting the Rocker assembly.
Old 02-22-2014, 11:02 PM
  #58
[IMG][/IMG]
The Heads on and all buttoned down.
[IMG]
[/IMG]
[IMG][/IMG]
Karcepts tensioner and Alternator bracket with OEM TypeS Alternator.
[IMG][/IMG]
[IMG][/IMG]
Ktuned Thermostat Housing.
Old 02-22-2014, 11:04 PM
  #59
[IMG][/IMG]
Finally found a Upper Water neck. With new hardware and Hybrid racing temp sensor adapter.
Old 02-22-2014, 11:11 PM
  #60
[IMG][/IMG]
New Timing chain with new hardware finally installed after buying three different chains apparently some places don't know that there is a difference between the k20 and k24 chains.
[IMG][/IMG]
Doing the Valve adjustment. Excuse the tape on the feeler gauge I use it so I dont mess up and get confused.
[IMG][/IMG]
Here is the Comp Clutch Ultra lightweight flywheel and Exedy three puck sprung carbon kevlar clutch installed with ARP hardware.
Old 02-22-2014, 11:22 PM
  #61
[IMG][/IMG]
This is my Skunk2 pro series black edition intake manifold. One problem though Its a 71mm or 72mm opening on the throttle body flange and I have a 74mm Skunk2 throttle body.
[IMG][/IMG]
Starting to fix the size difference issue
[IMG][/IMG]
Almost done!!!!!
[IMG][/IMG]
Done and smoothed out almost somewhat of a polish!!!!. I did this with all elbow grease machinist files, scratch pads, and sand paper. You have to be carefull because on about 1/4 of the opening about two inches back there is sloped turn off that is part of the design of this manifold do not remove it.
Old 02-23-2014, 06:39 PM
  #62
$MIKE$'s Avatar
^ lots of work man hope u get it together soon
Old 03-01-2014, 12:03 PM
  #63
Motor is just about complete. Will post pictures later. I had to tear the timing back apart due to sripped out bolt on the guides. Had to use a Helicoil.
Old 03-02-2014, 12:56 PM
  #64
Danger's Avatar
Nice work on the porting.
Old 03-30-2014, 09:04 PM
  #65
[IMG][/IMG]
The engine is all together now
[IMG][/IMG]
74mm Throttle Body
[IMG][/IMG]
Transmission with all the mounts and brackets on it
Old 03-30-2014, 09:05 PM
  #66
[IMG][/IMG]
S2000 CMC installed
Old 03-30-2014, 09:12 PM
  #67
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Installing the ECU, Conversion Harness, Fusebox. Almost done.
Old 03-30-2014, 09:15 PM
  #68
[IMG][/IMG]
[IMG][/IMG]
So when I installed my side engine mount bracket I realized I had clearance issues with my ABS. So I decided to delete my ABS. Here is the finished product. I am happy with the cleaner look.
Old 03-30-2014, 09:18 PM
  #69
[IMG][/IMG]
[IMG][/IMG]
When I tried to finish up the rear suspension. The Eibach Sway Bar did not clear the ASR subframe when attached to the LCA. So I upgraded to the ASR Sway Bar and ASR adjustable Endlinks.
Old 03-30-2014, 09:22 PM
  #70
[IMG][/IMG]
Eibach front Sway Bar and Endlinks installed
[IMG][/IMG]
Buddy Club Front upper control arms and Hardrace Front lower control Arms installed
Old 03-30-2014, 09:27 PM
  #71
[IMG][/IMG]
Buddy Club rear camber kit
Old 03-30-2014, 09:28 PM
  #72
[IMG][/IMG]
My Overflow Tank
Old 03-31-2014, 11:15 AM
  #73
Dc2_ShowStopper's Avatar
Great Progress !! Cant wait to see the outcome. GLWB
Old 03-31-2014, 03:57 PM
  #74
DirtyDA9's Avatar
Awesome build keep the pictures coming.
Old 04-02-2014, 09:47 PM
  #75
hondalocal's Avatar
Great build.
That's a serious parts list.
Keep it coming!
Quick Reply: ----- My Kswap, wire tuck, circut/drag track build of pepper My 1999 MR Integra-----
