My first Honda/Acura.. 99 integra GSR :)
So I recently bought this Integra, about 2 weeks ago. And I love it! The previous owner had sold B 18 C and swapped it B B 18 B with with a GSR head. LS/vtec. It has a first gen skunk 2 I.M. and 3inch downpiping. I'm not sure if it has any work done to the block or head, so I'm going to assume theyre both stock. I've heard from a lot of people that the ls/v can be really unreliable. I want to build this car so I can eventually boost it, and would like to make about 275 - 300 whp. What should I start upgrading/replacing so that this engine is reliable and strong. I don't plan on boosting it for a few months, I'm going to make a list and start on the small important things, but I need help with deciphering which parts those ate / what do I need to do (make stronger) before I boost it?
Thanks for the help and I'm glad to be part of Honda-tech
Re: My first Honda/Acura.. 99 integra GSR :)
Bump...
I just replaced my valve cover gasket, cam seal, vtec solenoid upper and lower gaskets, the upper portion of the vtec solenoid casting. I used permatex ultra black gasket silicone, ( http://www.permatex.com/products/pro...t-maker-detail )
I used the gasket silicone near the rounded portions of the gasket to ensure they're set correctly.
I flushed my oil thoroughly,and tomorrow I will do a fresh oil change and filter. I usr Castrol Edge Syntec. Full synthetic 10w30
its really nice man.exterior looks mean..hows that ls-v?is there a noticable difference from stock?ive been thinking of going ls-v with a b18a block/gsr head..but i dunno,i have a turbo anyways, so..lol.
whats the plans?
whats the plans?
Yeah man it runs strong. Definitely a big difference! I'm trying to go turbo. What are you running for turbo setup ?
Nice pick up looks soild keep it safe! Every time i buy a car I start out changing every single hard telling the last time they could have been replaced.
This is what is in my da9
B18a engine
B18b pistons/rods
Race rings
Oversized valves
B18b valve springs/retainers
B18b cams
10:1 fmu
I will be using my 14b turbo for that fast *** spool(full spool at 2800rpm)
Cast iron Mani
Ssqv Blow off valve
Xspower waste gate
Mishimoto fmic
Its got a 10psi spring in it right now,but I might try maxing the turbo(18psi) if its not enough..lol
No sir I will not be tuning.everyone is so reliant on technology..psh..old days ftw.
I do however plan on upgrading my fuel system.
I helped a friend get his turbo on a stock b16 eg hatch and I did it the same as how I plan to do it.he is going on 4 years daily driving it and he beats the sh*t out of it.I don't race.I don't beat my car.it will be fine.
Well my turbo isn't on yet,still need a fire ring and misc stuff,but I have most of it.an ex friend stole my $3000 turbonetics/drag/blitz turbo setup years ago...i never got to even use it,and it was brand new.all I really want is to get the experience I should have had...
B18a engine
B18b pistons/rods
Race rings
Oversized valves
B18b cams
10:1 fmu
Cast iron Mani
Ssqv Blow off valve
Xspower waste gate
Mishimoto fmic
B18a engine
B18b pistons/rods
Race rings
Oversized valves
B18b cams
10:1 fmu
Cast iron Mani
Ssqv Blow off valve
Xspower waste gate
Mishimoto fmic
I don't need name brand parts either, any help?
Be smart on eBay,and local deals etc is the best way to go when it comes to staying on the cheap and still having nice ****.
KoreanMoviesFTW
07-19-2010 06:17 AM
