My 92' DA build
Surje.motorsports
My 92' DA build
i had previously owned a DC5, so going from the beastly K down to a GSR was a bit sad to say the least lol. What the car looked like when i first took ownership;
year: 1992
make: Acura
model: Integra LS
miles: 204k(on chassis)
Motor Mods:
JDM B18C approx 40-50k miles
Blox Intake Maniofold w/Hondata IMG
ITR cams
Innovative mounts, ordered 60a received 85a, one mount also didnt fit correct so i only have 2/3 on the car at the moment, with one stock busted bushing mount
skunk2 alpha 70mm TB
reman'd and re-pinned 96-01 gsr integra distributor
IMW-spec 3" intake with vibrant v-stak
NGK Blue Plug Wires
Viton Valve Seals
Transmission:
YS1 cable and case
S4C 99-00' Si B16 1st-4th, ls 5th gears
Competition Stage 4 Clucth
Stock Flywheel
Suspension:
Innovative Traction Bar
Function and Form Type 1's
Blox LCA's(needs new bushings)
some unknown installed before i had the car upper front control arms
unknown rear camber kit
Stock sways
Exhaust:
Skunk2 Megapower
ebay Hytech Tri-y rep
IMW-spec 2.5" test pipe
Brakes:
Stock
BWR extended lugs
Exterior:
JDM Headlights
35% tint fronts and small rear windows, 20% on hatch window
OEM Front Lip
Interior:
Stock
Shoes:
15x7 +38 Kosei K1's
Kumho AST 205/50/15
Seek Speed lugs
Odds and Ends:
Skunk2 dual bend short shifter
ESMM shifter bushings
Circuit Hero SS Shift ****
New GSP axles
Transmission dis-assembly and re-assembly was done by Shaun Quickel of QCP Gear @ IMW
Tuned with Neptune by Derek Robinson @ Innovative Motorworks
plans for the future;
ksport 36 way adjustable full body coils
ksport LCA's
possible b20 bottom end, bored to 85mm with 12.5:1
ID725's(already have, just not installed)
aeromotive 340lph fuel pump(already have, just not installed)
dual map tune, one on 93 pump gas, one on e85 for the track
supertech VT
skunk2 pro 2's or 3's
50-75 direct port shot
new gas tank
JDP rear lip wing
battery relocation to the truck with cut off switch
exospeed VPD 13X8, 23.5 slicks
Thank You for looking everyone!
year: 1992
make: Acura
model: Integra LS
Motor Mods:
ITR cams
NGK Blue Plug Wires
Viton Valve Seals
Transmission:
YS1 cable and case
Stock Flywheel
Suspension:
Stock sways
Exhaust:
Skunk2 Megapower
Brakes:
Stock
BWR extended lugs
Exterior:
JDM Headlights
OEM Front Lip
Interior:
Stock
Shoes:
15x7 +38 Kosei K1's
Kumho AST 205/50/15
Seek Speed lugs
Odds and Ends:
New GSP axles
ksport LCA's
supertech VT
new gas tank
JDP rear lip wing
Surje.motorsports
Re: My 92' DA build
the parts...
BWR extended studs:
Vibrant piping and v-stack:
Skunk2 Alpha 70mm TB:
Comp Stage 4 Clutch:
NGK Plug Wires:
Hondata IMG
Blox Intake Manifold
Viton valve seals
ITR Cams
BWR extended studs:
NGK Plug Wires:
Hondata IMG
Viton valve seals
ITR Cams
Surje.motorsports
Re: My 92' DA build
more parts pics, installed JDM headlight pigtails, new h4h bulbs from password jdm, dizzy install.
Distributor/installed with NGK plug wires
Password JDM headlight conversion harnesses, look close, you will see them lol
B16 Transmission
motor mounts
Traction bar
B16 Transmission
motor mounts
Traction bar
Surje.motorsports
Re: My 92' DA build
some pics of the installs...
flying DA
parts sprawl lol
the mad shaunitist at work, disassembling, reassembling switching of the gears, etc..
putting new valve seals in and b16 dual intake springs in on the exhaust side
the mount that doesnt fit...
new bay shot...
thanks again for looking, that is all i have for now....
flying DA
parts sprawl lol
new bay shot...
Surje.motorsports
Surje.motorsports
Re: My 92' DA build
Re: My 92' DA build
Yeah man soon It will pull harder then your old DC5 and nice build with the DAs digging the K1s too.
Surje.motorsports
Re: My 92' DA build
Anytime dude your building a DA which I love more then any other chassis, I'm building one myself a shell very slowly don't have good funds yet lol but soon I hope. Also half of those parts you have in those pics are the parts I've been wanting to get for my DA for sometime now but i guess I'll have 2 find some different parts now except the traction bar from Innovative mounts!! really good price to get 1. Besides another dude from PA like me and a cool friend of mine building a DA I'll give 2
Surje.motorsports
Re: My 92' DA build
Mechanicsburg is located between Harrisburg and Carlisle, bout an 1 1/2 from philly on the turnpike
Re: My 92' DA build
lol thank you again...i have to say when i first got this car i hated it, the suspension was dropped way too low for pa roads, the motor was restricted so bad, its was just a straight up JDM GSR swap done by the previous owner, axles weren't changed, still had ls header, stock mounts, stock exhaust piping with a cherry bomb for a muffler lol...shitty advanced auto dizzy...the climate controls didn't work, barely had heat the first winter i had it, only one speaker worked...it was a nightmare to say the least but i am glad that the year of saving for parts was well worth it from where i started to where it is now.
Re: My 92' DA build
Word the 3 of us with our sexy a$$ DAs I'll be the only one in the group tho with no vtec got 2 have the crower 402s my DA shell is my first project and a lil new 2 Hondas still so work with me lol I get 2 excited.
Re: My 92' DA build
Oh yeah true about it being too low when u first got it, u know when your in PA with all the messed up streets and highways from all the bad, wicked snow and ice storms we get here. I have a big manhole on my block I have 2 evade all the time when i drive my friends Hondas cause penndot is 2 cheap 2 fix it.
Surje.motorsports
Re: My 92' DA build
i have updated the first post with my plans but ill list them here for you too
ksport LCA's
supertech VT
new gas tank
not exactly sure where that is lol, but an hour or 1 1/2 hours isnt bad if we can find a decent spot for a meet?
would love to go to IA, a few of us have been trying to go for years around here, the scene is a decent size out this way...
the only thing i dislike about my car as it sits right now is the damage i have on the passenger side behind the front wheel, i need a new door, new fender and some cut out and replaced with new aluminum...but that can wait til i get a new car within the next two years and the DA is taken off the road for major cosmetic repair...it will look brand new once all the body work and new paint is applied lol
ksport LCA's
supertech VT
new gas tank
Nice another dude into DAs like us Ken in PA, SWEET lol also he lives close to us I live in hazleton, pa close to nanticoke where LCCC campus is if u know? and dam that DA was a devils wear prada when u 1st got it sexy in the outside a nightmare in the inside! but nice build, I know I will be saving 4 those parts as well but not a year maybe half. Also I always take the turnpike the penna turn turnpike right I take that 2 go see dirtyda9 in philly, philly is a hour from me lol.
Surje.motorsports
Re: My 92' DA build
i believe the location of IA east coast changes each year to a different venue...i wouldnt mind rolling to honda day either.
Re: My 92' DA build
as soon as i saw the horizon gray, i already started liking the car lol. sucks to hear about the damage, i have a hg da as well. is yours original or was it painted? it looks a bit darker than mines in your pictures.
heres a old pic of mine from this past honda day in april
Surje.motorsports
Re: My 92' DA build
also been thinking about switching back to the usdm headlights, if i can source them lol, too make a vent to the velocity stak on my intake through the headlight hole....my jdm ones need polished and the light leveling adjuster is broken so my headlights point down, visibility is tough sometimes lol...or switching to the 91' front bumper and adding rectangle fogs for more visibility
