AT to MT conversion for 95 teg RS
Old Dec 7, 2002 | 04:27 PM
ptsiu's Avatar
Default AT to MT conversion for 95 teg RS
I have a 95 teg AT planning to do the transmission swap. Wondering what parts I need. Tranny?ECU?..etc...Hope somebody could give me a list and which is the best car I should get the parts from.
Old Dec 7, 2002 | 04:37 PM
Adriano's Avatar
Default Re: AT to MT conversion for 95 teg RS (ptsiu)
the best car would be an 94-01 integra.
Old Dec 7, 2002 | 05:24 PM
Davanca's Avatar
Default Re: AT to MT conversion for 95 teg RS (brryder)
You're going to need a pedal assembly, Shift linkage, Clutch master cylinder, slave master cylinder, an LS ECU, Clutch fluid cap, a manual gauge cluster, you have to change console piece thats comes with the cup holder and ash tray to the stick one. You might be able to get everything from a junk yard, except for probably the shift linkage and the master cylinder etc etc pieces. You might want to buy those new from the dealer.Thers probably some things i left out, but this is most of it.
ptsiu's Avatar
no matter it is RS,GSR or Type r?...and what parts do I need so that I can search for second hand
Old Dec 7, 2002 | 05:25 PM
ptsiu's Avatar
Default Re: AT to MT conversion for 95 teg RS (davanca24)
thx alot man.....too bad don't have much junkyard around here
Old Dec 7, 2002 | 08:56 PM
shamoo's Avatar
Will you make something up for me please?
Search the archives posts for my name and auto - manual posts. I made several posts about that after I did mine.
Old Dec 7, 2002 | 09:16 PM
mr_mbuna's Avatar
Default Re: AT to MT conversion for 95 teg RS (shamoo)
I may be able to provide you a complete complement of 5 speed conversion parts from a 1997 LS w/ 86k miles. Email me.
Ben
Old Dec 7, 2002 | 09:33 PM
AndrewJ's Avatar
https://honda-tech.com/zerothread?id=273253
Old Dec 7, 2002 | 09:34 PM
YumVTEC's Avatar
Default Re: AT to MT conversion for 95 teg RS (AndrewJ)
send a pm to 95EH, he sells auto to manual conversions... (pedal assembly, lines, clutch cylinder, etc...) then all you'd need is the tranny, shift linkage and ECU.
qtpnoiithug
Feb 12, 2008 07:18 PM
cheetah64
Jan 3, 2005 06:04 PM
raynaud
Aug 1, 2004 01:52 PM
Punkylemon
Apr 3, 2002 10:12 PM
