MSD Modified distributor cap install help????
Old Mar 9, 2003 | 06:28 AM
dingusjt's Avatar
Default MSD Modified distributor cap install help????
My computer sucks, i can pull up a search for it however whenever i click on a link my whole system freezes...so thats why i'm asking this again.
I need to know how to install an MSD modified distributor cap....either let me know in a reply or direct me towards a link with instructions, any help would be much appreciated. thanks
Old Mar 10, 2003 | 06:56 AM
dingusjt's Avatar
Default Re: MSD Modified distributor cap install help???? (dingusjt)
come on someone??? bump
Old Mar 10, 2003 | 07:02 AM
IC x Prince's Avatar
New User
uh...just screw it on.
if you mean all of the install. you will have to take out your interenal coil and wire the (+) and (-) to the new external coil. I had to "nick" the side of the cap to run the wires.
Old Mar 10, 2003 | 07:36 AM
VTECPWR's Avatar
Default Re: MSD Modified distributor cap install help???? (UltraPrince)
There are instructions at http://www.c-speedracing.com/
Old Mar 10, 2003 | 08:34 AM
dingusjt's Avatar
Default Re: MSD Modified distributor cap install help???? (VTECPWR)
ok thanks for the link...but i'm wondering whether it will be different instructions being that i am only using the MSD external coil and not the entire ignition box...from what i can tell there are only + and - terminals on the MSD Coil...these instructions describe 4 different wires and i'm sure that i only need 2.
I just need to know everything before i start ripping apart my distributor, thanks for any more help.
Old Mar 10, 2003 | 08:54 AM
New User
do you even read the other posts? or do you just read the last one?
Old Mar 10, 2003 | 09:53 AM
arw321's Avatar
The two wires are the + and - negative from your factory coil which is located inside your distributor. Remove the factory coil, feed the wires through the distributor grommet (this is a pain) and connect the two wires to the msd coil.
Adam
Old Mar 10, 2003 | 12:13 PM
Xsi's Avatar
Xsi
http://www.geocities.com/wyvnz/MSD.html
Truecure
May 19, 2005 10:09 AM
d16rice
12
Mar 23, 2005 03:41 PM
vaskater
Sep 15, 2003 10:11 PM
Adi Radoncic
Feb 14, 2002 11:03 AM
