MSD installation
drill a small hole to fit the wire through
the old wires that connected to the internal coil, you have to cut the connectors off and splice the wires and add longer wires
the black wire in the ground so it connects to the negative terminal of the blaster, then take the two other wires (i think they are white) splice, and extend and connect that wire to the positive terminal on the MSD
you should be good to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang »</TD></TR><TR><TD CLASS="quote">drill a small hole to fit the wire through
^^^^ what he said, the wires coming out of the msd are pretty self expanatory, the red & black are power/ground, there is an orange and another color on mine that goes to the Blaster coil, and the only 2 wires left are a white and i forget the last that goes to the inside of the distributor. On another note for $30 I just bought the cap that had the spark tower already on it.
</TD></TR></TABLE>^^^^ what he said, the wires coming out of the msd are pretty self expanatory, the red & black are power/ground, there is an orange and another color on mine that goes to the Blaster coil, and the only 2 wires left are a white and i forget the last that goes to the inside of the distributor. On another note for $30 I just bought the cap that had the spark tower already on it.
