Which MSD ignition to use?
Old Jun 12, 2002 | 04:37 AM
oldbeefcake's Avatar
Default Which MSD ignition to use?
I want to get a MSD ignition for my B18C1, should I get the SCI or 6AL? Let me know what you guys use? also which coil as well, ss or balster 2? Thanks>
Old Jun 12, 2002 | 06:17 AM
batboyvaj's Avatar
Default Re: Which MSD ignition to use? (Jun)
i would rather get a 6al...they have the revlimiter option on there and is more capable of adding other msd goodies. if you are interested...i'm trying to get rid of my 6al. its brand new never used or taken out of the box. i just decided i didn't want it and its just sitting there now. send me a msg and we can talk about this if you want
Old Jun 12, 2002 | 07:43 AM
vtecman's Avatar
Well I would get the SCI because its made just for imports and imports only. It does not matter if you get one with a rev limiter because your car still uses its stock rev limiter. And go with the Blaster SS coil its really good.
[Modified by vtecman, 8:43 AM 6/12/2002]
Old Jun 12, 2002 | 07:46 AM
eg6ajk's Avatar
unless you are going to use N2O or go FI setup, leave your distributor alone....
from few friends who had MSD units the distributors (igniter) didn't last longer then 8 months....be careful....
honda distributors can support 210whp and 9000rpm without any problems, so invest the many in something that will give you better gains
Old Jun 12, 2002 | 08:01 AM
batboyvaj's Avatar
Default Re: Which MSD ignition to use? (vtecman)
if you look at the specs of the 6al and the sci...they are the same. paying for the "sci" name. just what i thought....
Old Jun 12, 2002 | 08:51 AM
Hayasa15's Avatar
Default Re: Which MSD ignition to use? (batboyvaj)
What does the DIS-2 do?
lostforawhile
Jun 7, 2014 10:42 AM
racingant
Dec 27, 2005 01:18 AM
1slowcrx
Oct 28, 2004 04:33 AM
Captn. Save A Hoe
Nov 15, 2003 12:58 AM
Duck Sauce
Nov 16, 2001 08:19 PM
