Msd ignition question
Old Nov 25, 2005 | 07:07 PM
maxboost_50psi's Avatar
Default Msd ignition question
im planning on buying the msd 6a but between the 6a and the 6al all there is a rev limit does that mean that with the 6a i have no redline????
Old Nov 25, 2005 | 07:17 PM
gsrious's Avatar
it just means that you don't have the msd rev limiter. it's not really a big deal to havethe limiter.
**think of it this way...--> do you want to spend the extra money or so just to have a rev limiter.
Old Nov 26, 2005 | 04:00 AM
so if i buy the 6a i have no redline whatsoever. isnt the computer what determines the redline????
Old Dec 1, 2005 | 09:37 AM
thatHEMIguy's Avatar
Default Re: (maxboost_50psi)
its a rev. limiter... which is different from redline.. and i dont think you want to take your car to the limiter anyways unless you are built for it, or you will just beat the hell out of your motor
Old Dec 1, 2005 | 11:24 AM
95lstegman's Avatar
Default Re: (tonerboner95)
the ECU's limiter is harder on the motor than the MSD's limiter. if you're the kind that crashes into your limiter, get the MSD one.
BTW, pretty much everyone i've talked to says the MSD 6A/6AL setup is pretty bad for a daily driver. most have problems with it spontaneously dying and leaving them stranded within a year or so. just a "heads up."
Old Dec 1, 2005 | 09:43 PM
thanks for the help!! ill look into that man thanks
tigueremalo
Sep 4, 2006 01:31 PM
CIVICD16A9
Jul 4, 2005 08:26 AM
FastAllmotorLsVtec
Apr 16, 2004 11:12 PM
Rhetoric
Dec 16, 2001 12:05 PM
lundgren
Jun 19, 2001 01:01 PM
