Motor mount insert problem
Old Jul 2, 2004 | 12:31 PM
sleepin91teg's Avatar
Default Motor mount insert problem
Got a 91 integra, b18a1...cant get the rear prothane motor mount insert to fit...they even sent me a new one to see if it was a packaging mistake...part number is 8-512...anyone have problems like this?
Old Jul 2, 2004 | 01:08 PM
Default Re: Motor mount insert problem (sleepin91teg)
Anyone? im thinking im gonna cut it...
Old Jul 2, 2004 | 01:10 PM
Lord Helmet's Avatar
you tried greasing them up before you attempt to install them?
Old Jul 2, 2004 | 01:13 PM
Default Re: Motor mount insert problem (sleeperciv)
ya, got some dubyadeefoety on it...(WD40)
Old Jul 2, 2004 | 01:19 PM
try using a C-clamp or any type of clamp that can press the mount insert in. I still hope that's the correct mount kit they gave you.
Old Jul 2, 2004 | 01:48 PM
Im pushing it in a vice...its the right kit...i called prothane and summit racing (i bought it from them) and i just dont know right now?
Old Jul 2, 2004 | 02:09 PM
fergy016's Avatar
are you using the prothane kit or the energy suspension helper bushings? I have no information for you to get it to go into the rear engine mount. just press them in, you should be able to tell if it will fit before you do that.
Old Jul 2, 2004 | 02:22 PM
Default Re: (fergy016)
Prothane kit, its a 3 peice motor mount insert kit...left right, and firewall
Old Jul 8, 2004 | 01:05 AM
fergy016's Avatar
Default Re: (sleepin91teg)
i hope you got those pressed in. I don't know how far off from what they should be they are, but you might want to take it to a machine shop and see if they can press them in.
bunske123
Oct 10, 2007 10:50 PM
aznjay510
Jul 6, 2007 01:50 PM
hothotpete
Nov 22, 2004 11:12 PM
Thundersquid
Oct 23, 2003 10:43 PM
B94Cast
Nov 25, 2002 07:13 PM
