More rust grrr
Old Jul 28, 2014 | 02:35 PM
Alcatrax30's Avatar
Default More rust grrr
Was cleaning undercarriage and found rust eating on my gas tank i think, any advice how to remove this one ?
Old Jul 28, 2014 | 03:13 PM
deving916's Avatar
Default Re: More rust grrr
Its not bad, if its not leaking you should leave it.
I just went through this ordeal and it was terrible. You have to take the rear seats out, unbolt the fuel pump stuff, unbolt the metal bracket running across and unplug two plugs as well.
Then from under neath there are two straps and some other stuff. You'll need to use a jack with some wood to kind of jack it up and down and lower it slowly.
Also, there is a 17mm, I believe drain plug that will alleviate a lot of the weight too.
Be careful, fumes are dangerous.
Old Jul 28, 2014 | 04:16 PM
Alcatrax30's Avatar
Well lets say it does rust out it wont affect the chassis right? Since its removable?
Old Jul 28, 2014 | 08:02 PM
crazyhouse2011's Avatar
correct
HatchBox
Jul 3, 2004 10:23 AM
bmrgold
Jun 12, 2004 03:53 PM
austrian type-R
Jul 27, 2003 09:45 PM
p1ccoloz
Feb 27, 2003 05:57 PM
KooK
May 12, 2002 12:49 PM
