missing problem
Old Aug 17, 2004 | 09:56 AM
luvinmyGSR's Avatar
Default missing problem
ok well about a few weeks ago my car started missing real bad...liek from 1st to 2nd shifts ...so i replaced my dis cap and rotor and fuel filter and plug wires and thermostat....and it was fine for awhile ...then the other night it started missing again....but it doesent do it everytime...so i heard that getting the valves adjusted could be the problem...is this true...any suggestions would helpp....thanx
Modified by luvinmyGSR at 5:30 AM 8/27/2004
Old Aug 17, 2004 | 10:04 AM
Xymox007's Avatar
Default Re: missing problem (luvinmyGSR)
https://honda-tech.com/zero...10401
almost identical problem.
could be related to this: http://www.maximumautoparts.co....html
Old Aug 25, 2004 | 08:31 PM
luvinmyGSR's Avatar
Default Re: missing problem (Xymox007)
ok welll i had some bocsh plat.4's laying around that are brand new ..so i took my old ngk's out and but them in untill i can get a new set of ngk's...well it didnt miss at all , untill after awhile of drivin and then i got on it and it did it again....so should i go ahead and get the vavles adjusted???
Old Aug 25, 2004 | 09:09 PM
luvinmyGSR's Avatar
bump b4 i go to bed
Old Aug 26, 2004 | 08:13 PM
luvinmyGSR's Avatar
bump
Old Aug 26, 2004 | 08:30 PM
luvinmyGSR's Avatar
some 1 please help it gets on my nerves so bad
Old Aug 26, 2004 | 08:33 PM
XSrcing's Avatar
a high rpm miss can be numerous things: dirty injectors, bad plugs or wires, failing ignition module, loose sensor, loose connection.
Old Aug 26, 2004 | 08:37 PM
luvinmyGSR's Avatar
Default Re: (XSrcing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSrcing &raquo;</TD></TR><TR><TD CLASS="quote">a high rpm miss can be numerous things: dirty injectors, bad plugs or wires, failing ignition module, loose sensor, loose connection.</TD></TR></TABLE>
well i have new plugs, plug wires, fuel filter, and new cap n rotor.....what should i check next???
Old Sep 9, 2004 | 11:00 AM
luvinmyGSR's Avatar
Default Re: (luvinmyGSR)
after i get a new set of ngk plugs and it still does it should i replace the o2 sensors???i ****** hate when my car misses like this...it slows it down so much from about 5k on...i need some 1 to help me pleeeze....thanx
Old Sep 9, 2004 | 04:22 PM
luvinmyGSR's Avatar
bump
superdat1
May 1, 2008 10:20 PM
99blusi
Jul 13, 2006 10:03 AM
99blusi
Jul 11, 2006 11:56 AM
alfee
May 23, 2005 04:30 PM
89JDMcrx
Sep 9, 2002 11:11 AM
