Missing MAP Sensor Plug?
Old Sep 10, 2011 | 09:37 AM
TuwboBuddy's Avatar
Default Missing MAP Sensor Plug?
Hey guys I jus finished doing he head gasket on a 1993 inegra with a b20 swap in it and the car starts but dies pretty quick. It gives a little rev up by itself then dies. I'm missing the plug for the map sensor, can't find it anywhere...any help would be great thanks !
Old Sep 10, 2011 | 11:00 PM
Hidenplanvew's Avatar
Default Re: Missing MAP Sensor Plug?
Keep looking lol... By cap you mean electrical plug?
Old Sep 11, 2011 | 10:04 AM
TuwboBuddy's Avatar
I've searched and searched and searched....nothing! Is it possible when they swapped in the B20 they just never had it plugged in? I've traced all of the wiring on the harness pretty much and nothing....
Old Sep 11, 2011 | 10:31 AM
mouab18c1's Avatar
Is the harness uncut? Your car won't run properly without the map sensor.
Old Sep 11, 2011 | 08:42 PM
TuwboBuddy's Avatar
I don't believe it's cut...I didn't do the swap myself though, I've looked everywhere for the plug and nothing. So I guess my options are to either keep searching for it, or run a new one? My car won't stay on unless I give it gas, and when I try to drive it it bucks like a wild bronco...if I'm correct that is the symptom of a bad or unplugged map correct? T.I.A.
Old Sep 11, 2011 | 10:50 PM
Lsvsmoker's Avatar
You might have the tps and map plugs are the same, double check that
Old Sep 12, 2011 | 12:05 AM
mouab18c1's Avatar
Take a picture, I was thinking the same thing^^^ but I just don't see how a MAP connector would not be there if it has not been cut.
Old Sep 12, 2011 | 12:34 PM
TuwboBuddy's Avatar
Well I have the TPS plugged in, but there is no other plug to plug in anywhere....I mean before the head gasket job I truly don't recall if there was a plug in the MAP sensor or not (yes, retarded I know). I tried putting the plug that is on the TPS onto the MAP sensor but it didnt make any difference.
Old Sep 13, 2011 | 09:21 AM
TuwboBuddy's Avatar
Bump
Old Sep 15, 2011 | 02:01 PM
mouab18c1's Avatar
Get a new harness
Turbolude96
Sep 16, 2014 09:43 PM
oksblue
Mar 31, 2013 03:59 PM
jaredvabeach
Jan 30, 2007 01:44 AM
RudeLude95
Apr 14, 2005 11:30 AM
1337 Si
Apr 1, 2004 03:45 PM
