missing knock sensor
Old May 4, 2008 | 05:21 PM
MrViet's Avatar
Default missing knock sensor
So i don't have a knock sensor and my CEL is on. will this make my car any weaker?
since the knock sensor is just used to detect knock. 97 gsr btw.
Modified by MrViet at 6:36 PM 5/4/2008
Old May 4, 2008 | 06:41 PM
ITRICED's Avatar
Default Re: missing knock sensor (MrViet)
dude get a knock sensor. this is off of wikianswers
"The knock sensor responds to spark knock caused by over advanced timing. A knock is a sudden increase in cylinder pressure caused by preignition of the air fuel mixture as the flame front moves out from the spark plug ignition point. pressure waves in the chamber crash into the piston or cylinder walls resulting in a sound known as a knock or ping. this is caused by using a fuel with a low octane rating, overheating, or over advanced timing. sometimes it can be caused by hot carbon deposits on the piston or cylinder head that raise compression."
Old May 4, 2008 | 08:10 PM
MrViet's Avatar
Default Re: missing knock sensor (ITRICED)
alright i still didn't get my answer though haha. good info though thanks.
back to the original question....a missing knock sensor means my car is slower or..........not?
Old May 5, 2008 | 10:18 PM
MrViet's Avatar
bump. anyone know? it should be an easy question to answer haha. i just wanna set my priorities.
Old May 5, 2008 | 10:37 PM
integ401's Avatar
I would just in case you get bad tank of gas. Without it. It'll just ping itself to death over time
CaliforniaDad
Mar 14, 2016 04:45 PM
98vtec
Aug 18, 2006 07:12 PM
co_OlLo_OdDo_Od
May 3, 2006 11:36 PM
DR. ON POINT
Dec 12, 2001 12:26 PM
