maintenance required light on
If you look under the dash you will see a little button.. I believe mine is blue, not 100% sure. Press and hold button while key is switched to on position.
I'm not exactly sure when the light comes on or the intervals.. In for more info, if someone does indeed know.
I think it is the indicator/reminder for oil change. It is simple to reset, as noted, but mine is on the backside of the plastic and I find it by feel. Never crawled under to see the color.
