maintenance required????
Old Oct 16, 2001 | 01:19 PM
FlipboiGSR's Avatar
New User
Default maintenance required????
im not sure if my car really needs maintenance. everytime i start my car every light(engine, ABS, maint req, etc.) lights up like usual. then when every thing else turns off the maintenace req. light blinks for a minute or so. do i need maintenance for my car. is it probably cause i need an oil change?
Old Oct 16, 2001 | 01:22 PM
Chris's Avatar
Default Re: maintenance required???? (FlipboiGSR)
this is TOO MUCH.
HELLO!!!! Ill USE THE SEARCH and see what I can find FOR YOU.
https://honda-tech.com/zerothread?id=74716
Old Oct 18, 2001 | 05:32 AM
ANACC2NV's Avatar
New User
Default Re: maintenance required???? (Chris)
ya you may need regularls sceduled maitnence!the light is just to tell you, you need it..its not manditory though.
of you dont re-set the button after a while the light will just stay on all the time..
there is a re-set button under the steering column on the right side..its a little green button, just hold it down for 10 sec and it will re-set
kloscivicsi
Honda S2000
Mar 30, 2007 05:05 PM
dc5r27
13
Dec 4, 2004 03:19 PM
gsr_to_the_MAX
Mar 2, 2004 07:56 PM
JBBNJ609
Sep 12, 2003 01:39 PM
Tegra
Aug 9, 2002 07:04 PM
