maintenance required
Old Jul 29, 2009 | 09:25 PM
JJtegfan14's Avatar
Default maintenance required
so a couple days ago i started my car and my maintenance required light came on my dash. I asked my brother who knows a thing or two about honda's said not to worry since my CEL wasn't lit he said it was a dealership thing and doesn't matter if my car was running fine.
SO is he right and how do i get it to stop.
Also if anyone knows how to get the ABS light off to that would be helpful
Old Jul 29, 2009 | 09:33 PM
dapek's Avatar
Default Re: maintenance required
For a quick fix, reach under your steering wheel under the dash, directly left of your cd player assuming your car is a 94-01 there will be a button underneath. Turn your key forward and hold the button. The maintenance light should turn off.
Old Jul 29, 2009 | 09:38 PM
ek-g6's Avatar
yes it should be the color blue. Have you checked the abs light for codes?
Old Jul 29, 2009 | 09:49 PM
JJtegfan14's Avatar
no but the abs light was on when i bought the car the previous owner said that it was a bad sensor. i don't care if it works or not but it annoys me to see it there
Old Jul 29, 2009 | 09:53 PM
ek-g6's Avatar
I would just take that abs light bulb from the cluster. thats what i did with mines. I hate abs when it messes up!
Old Jul 29, 2009 | 09:56 PM
dapek's Avatar
I would recommend having the ABS checked out before just pulling the bulb for it. Doesn't that sound a bit unsafe?
Old Jul 29, 2009 | 09:59 PM
JJtegfan14's Avatar
true i works i had to use it once and it didn't lock up or i got lucky. BUt i heard there's a way to reset it anybody know it
Old Jul 29, 2009 | 10:05 PM
JJtegfan14's Avatar
Old Jul 30, 2009 | 08:41 AM
Nak's Avatar
Nak
to reset the maintenance require light, turn the key to the on position while holing the little square button under the dash below the steering wheel towards your right i believe
raene
May 30, 2013 03:13 AM
Purple94EX
31
Jul 13, 2006 04:43 AM
fabe85
Nov 29, 2004 09:32 AM
EGcivicBoy
May 6, 2004 02:24 PM
