Maintenance Required
Old Mar 3, 2007 | 10:50 AM
peggedteg's Avatar
Default Maintenance Required
Hey guys, I have a 97 integra gsr with 135000 miles on it. I just got the oil changed and everything seems to be ok. The problem I'm having is the maintenance light. I know how to reset it (push in the button under the dash), but for some reason it won't turn off. I asked a guy at pepboys and he said it's an engine problem and i need to have an engine diagnostic run. I thought, the maintenance required light was linked to the odometer not the engine. Could this be a serious problem?
thanks
andrew
Old Mar 3, 2007 | 10:53 AM
ANONYMOUSdeecee's Avatar
Default Re: Maintenance Required (peggedteg)
u gotta reset the light......its does not rerally mean u gotta maintane ur car its jus a anoying light
Old Mar 3, 2007 | 10:54 AM
peggedteg's Avatar
Default Re: Maintenance Required (ANONYMOUSdeecee)
Yeah, I did try to reset it myself, but the light won't go off.
Old Mar 3, 2007 | 10:59 AM
http://www.team-integra.net/se...D=164
that tell u how to reset it
Old Mar 3, 2007 | 11:07 AM
ac_attak's Avatar
The guy at pep boys must have been thinking of the check engine light. The maintenance required light is just a reminder. If you couldnt reset it maybe you were doing it wrong?
Old Mar 3, 2007 | 11:59 AM
james_ls's Avatar
5 seconds while key is on accessory.
Old Mar 3, 2007 | 12:09 PM
__oversea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ANONYMOUSdeecee &raquo;</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...D=164
that tell u how to reset it </TD></TR></TABLE>
/thread
Old Mar 3, 2007 | 12:40 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (james_ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james_ls &raquo;</TD></TR><TR><TD CLASS="quote">5 seconds while key is on accessory. </TD></TR></TABLE>
Yes, you need to hold it in until it goes out. Don't just press it quickly. It should stay full on for a second or two, and then go out entirely.
Also, press it ALL the way in. The center of the button is fairly deep.
I'm just glad this wasn't another topic asking how to reset the light, since we already have a gazillion of those.
yeahyeah1469
Oct 2, 2010 01:04 AM
marinersfaninmd
Acura TSX
Jun 15, 2009 07:24 PM
krotter
Jun 26, 2007 05:46 PM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
Brian-Brian
Jun 6, 2003 01:49 AM
