Maint Required
Old Jun 6, 2007 | 06:10 AM
HondamanXxX's Avatar
GO GIANTS!
Default Maint Required
My buddies integra's Maint Required light is on. The car has 103k miles. Anyone know why?
Another question is when the lights turn off, i press on the brake pedal and all of the interior lights go on. Dont know why.
ANother thing is when the lights are on and then I put the brakes on, the brake lights on there dont get very bright. Not much of a difference.
Any help?
Old Jun 6, 2007 | 06:15 AM
johnnyscarecrow's Avatar
Default Re: Maint Required (HondamanXxX)
That light usually comes on every 3,000 miles or so to remind you of oil change.
Put key in ignition, turn to first click. Under dash there is a little button, hold that button down for 3 seconds and it will reset....
I think thats right.....
Cant help with the lights....maybe check fuses and make sure there are no grounding issues....
Old Jun 6, 2007 | 06:17 AM
GO GIANTS!
Default Re: Maint Required (johnnyscarecrow)
Thanks for the help. Anyone else got any ideas?
Old Jun 6, 2007 | 07:12 AM
98BabiGs-T's Avatar
I don't think it comes on every 3k mile... I think its like some 70k or something like that and it pretty much means what it says... "Maintenance Require". As long as your up to par with keeping your car up and running (changing oil, etc) then you should be find. Just reset it.
Here some info.
https://honda-tech.com/zerothread?id=1699530
http://www.team-integra.net/se...D=164
Old Jun 6, 2007 | 09:50 AM
GO GIANTS!
Default Re: Maint Required (98BabiGs-T)
Bump..maybe the Altinator?
Old Jun 6, 2007 | 10:27 AM
GO GIANTS!
anyone ever have this problem?
Old Jun 7, 2007 | 09:35 AM
GO GIANTS!
bump
Old Jun 8, 2007 | 12:35 AM
98BabiGs-T's Avatar
This might be stupid... but did you checked the bulbs/fuses/lines/cables/etc...?
91efbluehatch
23
Jan 6, 2011 06:42 PM
toolbox21
Mar 17, 2009 08:31 PM
xjohnny817x
Aug 29, 2007 12:47 AM
redacura
Mar 13, 2003 03:43 AM
