Main Input Shafts Interchangeable?
Old Apr 22, 2009 | 07:11 PM
Turbo-GSR1287's Avatar
Default Main Input Shafts Interchangeable?
Well i finally got my trans pulled apart today and because of a wrongful assembly of washers, and gear assembly on the mainshaft (by the guy that did it ) my main input shaft was completely fvcked up.
Needless to say my question is this:
My transmission is a Type R transmission and the part number for the Main input shaft from acura is : 23210-P21-020
Now i was planning on just using the main input shaft from my old GSR transmission and just swapping everything over to that but sadly the part number for a GSR Main Input Shaft is: 23210-PS1-A04
can someone tell me what exactly the difference between the two mainshafts are and if it is possible to use the GSR Mainshaft w/ the Type R everything else.
Thanks
Old Apr 22, 2009 | 07:13 PM
sp00ledbseries's Avatar
Default Re: Main Input Shafts Interchangeable?
I think they are interchangeable. BUT im not 100% sure
Old Apr 22, 2009 | 07:46 PM
k.... any 100% for sures?
Old Apr 23, 2009 | 04:48 AM
redflaredcrx90's Avatar
no there 2 diffrent parts bud type r is a short geared tranny than the gsr so the tooth count on the gears are diffrent look at this http://www.ff-squad.com/tech/temp/Bgears.htm
boost ben
Transmission & Drivetrain
Jun 12, 2015 05:16 AM
civic89si666
Dec 24, 2009 10:25 PM
092eg6
Nov 20, 2009 10:20 AM
Turbo-GSR1287
Apr 22, 2009 09:11 PM
