main bering caps
Old Dec 7, 2001 | 02:45 PM
One8Hatch's Avatar
New User
Default main bering caps
how do you remove the main bering caps after you removed the bolts with out messing up anything? there awfuly stubburn. thanks
Old Dec 7, 2001 | 02:50 PM
HX_Guy's Avatar
Default Re: main bering caps (One8Hatch)
Hammer my friend
Just tap on the side, switching frm one side to the other...tap kinda in a upward motion..theyll come loose.
Hey, I noticed you have the 404 cams, how is you idle? Real rich?
Old Dec 7, 2001 | 03:30 PM
One8Hatch's Avatar
New User
Default Re: main bering caps (HX_Guy)
eh, i didnt have a a/f or egt when i had the cams, i set it at stock idle and it would die on me, so i bumped it up to 1k, i need to get a s-afc and some adj. cam gears, also power under 4k isnt too good. im in the process of upping my compression so i'l see how it is, but i would reccomend the 404's tho, im willing to sacrafice a little bottom end. wouldnt a hammer too rough? even if i tap it lightly? thanks
haulinhonda
Mar 11, 2013 02:11 AM
codyw
Feb 1, 2009 08:52 PM
legendboy
Aug 29, 2002 06:20 AM
HX_Guy
Jun 13, 2002 09:52 AM
