Lug Nut Problem
Old Mar 17, 2003 | 06:41 PM
grngsr01's Avatar
Default Lug Nut Problem
I got a set of 17s and they vibrate sometimes around 65-75 mph. Some guy at the speed shop told me that I got the wrong lugs for the wheels on them, i thought he was bull ****. The wheels were just balenced also.
Could lugs cause this problem???
Old Mar 17, 2003 | 06:42 PM
fivespeedintegra's Avatar
Default Re: Lug Nut Problem (grngsr01)
did you get "tuner" lugs?
if not...sure, lugs could be the problem since they probably aren't tightening enough.
Old Mar 17, 2003 | 07:20 PM
grngsr01's Avatar
Default Re: Lug Nut Problem (fivespeedintegra)
i got the wheels from wheelmax.com and they came with lugs. I do not know if they are tuner lugs or not, but i would guess not. That ******* company sucks. They didn;t even supply hub centric rings, they claimed they are not necessary.
Old Mar 17, 2003 | 07:30 PM
tilt's Avatar
There's conical/tapered/tuner lugs and acorn lugs. If they have rounded/bulge seats it is acorn. If it is slanted but straight seat they are conical. You probably need conical lugs for aftermarket wheels. And yes it is important you have the right one... lugs can back out and strip the wheel studs, or even worse break the studs and the wheel fall off.
[Modified by tilt, 10:31 PM 3/17/2003]
Old Mar 17, 2003 | 07:40 PM
grngsr01's Avatar
Default Re: Lug Nut Problem (tilt)
Thanks for your response, so lugs could cause a vibration. the ones that are on ther enow are a spline drive...
Old Mar 17, 2003 | 08:03 PM
.RJ's Avatar
.RJ
If the lugs came with the wheels its probably not the issue. Your wheels need to be re-balanced.
Old Mar 17, 2003 | 08:15 PM
Rtzx9r's Avatar
GDD 1%
Default Re: Lug Nut Problem (.RJ)
Balance issues are always right around 60mph, and come on and go away like a switch being turned on/off.
If the wheel was not "centered" or "seated" correctly b/c of bad lugs of no hub-centric ring, you would notice the vibration at ALL speeds.
Try putting the back wheels o nthe front and the fronts onto the back- if the vib goes away, your problem is balancing.
It also depends on how they balanced the tires- a static balance (weight in drop center of rim), just putting the weight on the inside of the rim, or with weights on both sides of the rim also can make a diff. Putting weights onto just the center or inside is not as good a balance.
Make sure they use STICK-ON weights too- so they do not mess up your rims.
Old Mar 18, 2003 | 07:55 AM
grngsr01's Avatar
Default Re: Lug Nut Problem (Rtzx9r)
The consensis seems to be pointing at balencing. Are these wheels that hard to balence. Why do I have stupid *** problems like this all the time...
Old Mar 18, 2003 | 09:02 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Yes, lug nuts are probably the problem. My friend forgot his set for his Spoon rims for the track and when we were going around the road course the lug nuts vibrated loose and we had to cut the session short to re-tighten them. So be careful as well. You don't want to lose a rim or your life.
Old Mar 18, 2003 | 10:08 AM
.RJ's Avatar
.RJ
They're not hard at all to balance. Will cost you $20 or so for all 4 wheels.
This is car ownership. Deal.
Old Mar 27, 2003 | 07:08 PM
grngsr01's Avatar
[QUOTE]
QUOTE]
I know that much.
What are tuner lug nuts?
Password Jdm
Feb 20, 2009 08:56 PM
JDR
Oct 16, 2005 08:50 PM
importdreamer
Nov 10, 2004 09:52 AM
grngsr01
Mar 28, 2003 09:06 AM
f22bToSlow
Oct 23, 2002 11:25 AM
