Ls vtec setup?
Old Feb 25, 2010 | 12:51 PM
KGB_JDM's Avatar
Default Ls vtec setup?
I'm looking to do a ls vtec swap in my 97 teg ls. I have a bare ls block and a bare b16 head with bronze guides. Is this a good setup for doing lsvtec swap? I know there is a thread for this but I couldn't find it (can someone post the link)...also what tranny would best work with this setup? I have an ls tranny but if need be I'll buy a different one...
Thanks Thomas
Old Feb 25, 2010 | 02:12 PM
95 integra's Avatar
Default Re: Ls vtec setup?
Sounds like a good start. GSR trans is good for a ls/vtec, depending on how high youre going to rev it.
Old Feb 25, 2010 | 02:18 PM
DumaDA's Avatar
b16 trans would be better though, short *** gear ratios
Old Feb 25, 2010 | 02:23 PM
KGB_JDM's Avatar
Sweet...I'll probably pick up a b16 tranny then...also what ecu should I use?
Old Feb 25, 2010 | 02:27 PM
DumaDA's Avatar
are you going to leave your car as obd2? or you plan on converting to obd1 for more tuning options?
Old Feb 25, 2010 | 02:35 PM
KGB_JDM's Avatar
I didn't know which one I should go with...I have no idea how to build a motor so I'm up for any advice
Old Feb 25, 2010 | 02:39 PM
mouab18c1's Avatar
You will need to convert to obd1 to be able to tune it.
Old Feb 25, 2010 | 02:41 PM
KGB_JDM's Avatar
Then I'll convert it..what ecu should I use?
Old Feb 25, 2010 | 03:22 PM
DumaDA's Avatar
you can get an obd1 gsr ecu or you can get a chipped P28 ecu
http://phearable.net/ has ecus and tuning options as well, they can do your obd1 conversion with your ecu and dizzy too
Old Feb 25, 2010 | 03:23 PM
neverstop's Avatar
if you don't know how to build a motor you're better of getting someone else to build it or good chance you'll blow it up. Most everyone blows up their first motor they build whether it is a small block 350 or a motorcycle. If you need to daily drive it just have it built.
Old Feb 25, 2010 | 05:17 PM
KGB_JDM's Avatar
ill build it myself, but i have family that own machine shops...and mostly anything to deal with cars. Im also an aircraft mechanic for the usaf on C5 cargo planes so i have some experience, but this will be my first lsvtec build. I have done a ls rebuild with one of my friend but nothing to big.
Old Feb 25, 2010 | 08:19 PM
SolAddiction206's Avatar
your gonna have to do some research to find out what your building it for. kinda hard for us to tell you what you should do. oh and theres like a 100 page thread on how to build one.
good luck and have fun.
Old Feb 26, 2010 | 03:01 AM
KGB_JDM's Avatar
Can anyone post the link to how to build one..I know of most of the parts I will need just clueless on a few
Old Feb 26, 2010 | 04:08 AM
SmYrE's Avatar
If you search ls/vtec build on the search bar you couldnt have missed all the possible links....but here you go.
https://honda-tech.com/forums/showth...ble+vtec+build
Old Feb 26, 2010 | 04:16 AM
wastedyouth2542's Avatar
https://honda-tech.com/forums/acura-integra-6/how-use-honda-tech-search-engine-2585253/
Old Feb 26, 2010 | 05:41 AM
95 integra's Avatar
Better if you have the redline to support it. 6500-7k isnt that great with a B16 trans. 8500+ and you're fine....assuming you dont have a turbo w/ tons of torque either.
Old Feb 26, 2010 | 05:55 AM
KGB_JDM's Avatar
no turbo yet, i have plans to put one on next winter when the car goes my garage for the winter...
overall what would be the best tranny to get? gsr or b16? ill probably rev it alittle high.
Old Feb 26, 2010 | 11:07 AM
super jdm yo's Avatar
i've had both b16 and gssr transmissions on my ls/v and for me daily'ing my car more now gsr is way better.
what's your plans for this motor what use is it going for? answering that question is going to dictate your build and help others to help you. good luck with the build.
Old Feb 26, 2010 | 11:13 AM
KGB_JDM's Avatar
It's going to be a DD for this spring and summer...it has a b18b1 in it now...i'm trying to get around 250 whp if more that's fine...
Old Feb 26, 2010 | 11:17 AM
DumaDA's Avatar
ok if you want good gas mileage gsr is better because the gear ratios are longer, if you want acceleration, b16 is better because it has shorter ratios
Old Feb 26, 2010 | 11:24 AM
KGB_JDM's Avatar
Old Feb 26, 2010 | 11:27 AM
95 integra's Avatar
DD ls/vtec = GSR Transmission in my opinion. Keeping in mind that I currently have a B16 w/ 4.785 FD installed currently and it turns over at 4700ish at 80mph vs 4k like a GSR.
Old Feb 26, 2010 | 11:38 AM
KGB_JDM's Avatar
I'm not worried about gas mileage if it's in the 20ish range that's fine...I can afford gas prices lol...after the swap I would probably run premium 93 anyways...I want power but also be able to drive it daily...
Old Feb 26, 2010 | 11:44 AM
DumaDA's Avatar
plenty of people daily drive b16 trannys, the only reason they prefer gsr is because it revs a little lower. So you're going for 250whp on Lsvtec turbo set up?
Old Feb 26, 2010 | 12:30 PM
KGB_JDM's Avatar
yea that will be my setup that i will end with. just now im going with just the lsvtec swap then throw a turbo on it.
