ls vtec research...
Old Nov 2, 2002 | 02:23 AM
CharleyCRX's Avatar
Default ls vtec research...
i'm sure at 1000% somebody wrote how to build an ls/vtec... all the parts we needs... so I don't know what writting in "search" (i'm too bad in english)
so if someone can help me to do the research... tx you
Old Nov 2, 2002 | 05:00 AM
NeXTLeVeLGeN2's Avatar
Default Re: ls vtec research... (CharleyCRX)
need a b series ( complete ) Vtec Head
Need a ODB1 VTEC ECU , Flat hex screw to plug oil feed on Vtec head , Suggest a V-AFC Controller...and some internal work on the block...stock LS/VTEC's run like low 14's maybe high 13's stock....I would port head , intake manifold , exhaust manifold , throttle body , block if you want bore it....forged rods , pistons , titanium retainers and springs , change cams if you have the money...Skunk2's I heard are pretty good...thats the set up im going with..My car would be done but Fukin acura...I decided to re-do all the bearings in the block and 2 " green " main bearings are on ****** back order....
keep u all posted..
Old Nov 2, 2002 | 06:14 AM
Vu's Avatar
Vu
http://www.c-speedracing.com/howto/lsvtec/lsvtec.html
Old Nov 2, 2002 | 08:44 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: ls vtec research... (Vu)
that's where i got my info
Tong.Y
Dec 7, 2009 10:02 PM
fv8s
Oct 19, 2009 09:43 AM
snaileg
Dec 6, 2006 06:42 AM
DrewQ1
Jul 16, 2004 12:41 AM
gsx0r
Sep 15, 2001 01:33 PM
