LS-VTEC PLEASE HELP HELP HELP
Old Nov 21, 2007 | 11:26 AM
tpham_autotecks's Avatar
Default LS-VTEC PLEASE HELP HELP HELP
I HAVE 95 GSR BUT THE BOTTOM HAD A HOLE, THE HEAD IS STILL GOOD, SO I WENT TO BUY A LS SHORT BLOCK, I'M TRYING TO HAVE THE CAR RUN AGAIN WITHOUT BUILD. SO MY QUESTION IS DOES THE GSR HEAD BOLT RIGHT ON THE LS SHORT BLOCK WITHOUT MOD? OR I HAVE TO RETHREAD THEM TO FIT?
THANK YOU
Old Nov 21, 2007 | 11:45 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: LS-VTEC PLEASE HELP HELP HELP (tpham_autotecks)
LS-VTEC PLEASE SEARCH SEARCH SEARCH
Old Nov 21, 2007 | 11:55 AM
IZEONLI's Avatar
Block Modifications
Before bolting down the new head, a few modifications NEED to be made to the block. Normally, on a VTEC engine, oil is fed to the VTEC pressure switch by an orifice on the deck of the cylinder head matching up with a corresponding hole on the deck of the block. Since the LS has no such hole, and you want VTEC to work, you need to be creative.
Old Nov 21, 2007 | 11:58 AM
IZEONLI's Avatar
All B-series VTEC ECUs will require you to use a knock sensor. Unless yours was reprogrammed to not look for one, one will have to be retrofitted into the block since there aren't any provisions for one on the LS. Some non-VTEC engines have a blank spot on the rear of the block where the threaded hole would normally be drilled on a VTEC modelIf you're lucky to have this blank spot on your block, use a 10.9mm bit and drill a hole deep enough to run a 12mmx1.25mm tap through it a few turns. For those not so lucky you'll have to either find another spot on the block where a hole can be drilled or have your ECU reprogrammed. Throwing a knock sensor malfunction code automatically disables VTEC. With our Civic, a Hondata-modified ECU was used, which did not require a knock sensor. The Hondata unit will also allow us to extract additional horsepower from the engine later on, thanks to its fine-tuning capabilities
Old Nov 21, 2007 | 12:02 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: LS-VTEC PLEASE HELP HELP HELP (IZEONLI)
where did you copy and paste your posts from?
Old Nov 21, 2007 | 12:06 PM
AWD Terror's Avatar
Default Re: LS-VTEC PLEASE HELP HELP HELP (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">where did you copy and paste your posts from?</TD></TR></TABLE>
He wont say b/c he's just so smart that he wrote that himself!!!
OP: there are thousands of threads about LS/Vtec. Search for them
Old Nov 21, 2007 | 12:39 PM
IZEONLI's Avatar
Default Re: LS-VTEC PLEASE HELP HELP HELP (AWD Terror)
not trying to be smart just copied it so that i wont screw it up thats all its where i get my answers from
Old Nov 21, 2007 | 01:42 PM
St Jimmy's Avatar
* B A N N E D *
http://www.sportcompactcarweb.....html
Old Nov 21, 2007 | 01:47 PM
GSR in progress 96's Avatar
* B A N N E D *
https://honda-tech.com/zerosearch
steinie88
Jun 26, 2010 12:40 AM
poorman's type-r
Jul 28, 2006 04:10 PM
a1320addict
May 9, 2005 12:43 AM
aira
Dec 24, 2003 12:40 AM
sicilian2k1
Sep 2, 2001 10:39 PM
