LS/VTEC initial start up and idle issues
Old Aug 14, 2014 | 08:19 PM
dark_reverie's Avatar
Default LS/VTEC initial start up and idle issues
Hi guys.
I recently did a LS/VTEC swap with a gsr head, and i wasn't getting oil pressure. The throttle body leaked from the gasket, and now both issues are fixed. However, upon start up the car dropped right down to 400-500 rpm, and ran very rough. I didn't want to let it warm up, as I was afraid something could be damaged. IACV was off the LS and it idled fine. idle screw was all the way in and backed off 1-2 turns. Very rough running at idle, but at 1000+ rpm it smooths out
my TPS isn't adjusted yet, and I haven't bled my coolant because the engine has not been warm enough yet. I have no FITV.
Codes pulled were
8 - TDC position
7 - Throttle angle
21 - VTEC solenoid (I haven't grounded it yet)
no misfire codes
as far as my understanding goes, TPS shouldn't affect idle.
what could be wrong? I'm pretty sure I don't have a vacuum leak either. Should I let the engine get to operating temperature first?
Old Aug 14, 2014 | 10:14 PM
Default Re: LS/VTEC initial start up and idle issues
what goes in this hole? I noticed it was left open.. and the vacuum line off the intake manifold that i Have plugged in the middle of the picture. where does that go?
Old Aug 15, 2014 | 12:39 PM
wunfstgsr's Avatar
Loved
Community Favorite
Set your Tps calibrations first it does effect the idle!
The TDC code I'm not sure about its a sensor on the oil pump i think.
The lower hose you have blocked off I'm 99% sure that goes to the PCV valve and black breather box on the back of the block.
Just plug that hole with a bolt and after everything see if the motor runs better.
B18_badboy
May 1, 2011 04:43 PM
hondaboi7
Apr 11, 2011 11:42 AM
be8teensee1
Aug 19, 2007 08:57 PM
vtecda
Aug 15, 2005 07:41 AM
boiwitwhitehond
Nov 4, 2004 07:50 AM
