ls/vtec block
Old Jan 27, 2006 | 01:18 PM
7thgenRS's Avatar
Default ls/vtec block
i won't to build a ls/vtec turbo setup. i am going to have RLZ to go threw the whole bottom end. they are going to put eagle rods,wiseco pistons,darton sleeves,type r oil pump,water pump and timing belt.how reliable and how long will this engine last?thanks
Old Jan 27, 2006 | 01:30 PM
LSvtec03's Avatar
Default Re: ls/vtec block (7thgenRS)
sounds like you got it covered. if they do a good job plugging the head and routing the oil line, it should be as reliable as any stock honda.
....as long as you take care of it, that is.
Old Jan 27, 2006 | 06:16 PM
ernald711's Avatar
it all depends on the tuning and how well all the parts are slapped together. besides that, all the physical parts'll work good well together.
Old Jan 27, 2006 | 06:20 PM
shorto85's Avatar
Good tuning and proper break in it will last a while. Also how you drive it to will affect the life.
cbabyby
Aug 12, 2013 03:28 PM
libral00
Mar 30, 2008 09:57 AM
GRIMEY.STREET.RACER
Nov 1, 2002 11:42 AM
lube
May 12, 2002 07:35 PM
Cyrio
Mar 9, 2002 11:58 AM
