LS Vtec??
Old Dec 18, 2002 | 08:18 PM
WatchemSpin's Avatar
Default LS Vtec??
I have a buddy selling me a GS-R VTEC head off a 97 GS-R with 50k and the ECU, he only wants 300 bucks for it, will this end up being an expensive projecT? or will i not need much more? I heard that LS/VTEC pushes out just as much HP as a Type- R, is this true?
[Modified by WatchemSpin, 9:32 PM 12/18/2002]
Old Dec 18, 2002 | 08:49 PM
lsteggy's Avatar
Default Re: LS Vtec?? (WatchemSpin)
you can make it a cheap project if you want but you need to spend some cash to make it run well.
Old Dec 18, 2002 | 08:50 PM
lsteggy's Avatar
that is a really good deal though on the head and ecu. if you dont want it then hook me up with it.
Old Dec 18, 2002 | 09:00 PM
Quik Chris's Avatar
Well here's the thing. It's all good and grand if you were to just swap the head and the ECU out, but here's the thing. To really reap the benefits from the head, you're going to want to get rid of that 9.2:1 Compression ratio. I'd highly recommend getting P30 JDM B16 pistons, PR3 (USDM B16) or ITR pistons are good as well, or if you want to go super-crazy, get some PCT pistons high 12.5+:1 compression.
You'll need to get the dowel pins moved on the GS-R head as well. Is he including the distributor and intake manifold too?
Old Dec 19, 2002 | 08:48 AM
Do I have to get the head bored for the dowel's? what about the oil lines? if i dont have the intake manifold and distributor. can i still make it work? can i just bolt on the head, and swap the ECU? im on a low budget, ya feel me? haha, plus im still a novice, sorry if my questions might sound dumb
Old Dec 19, 2002 | 08:58 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
You should probably do some research before you decide to go ahead with this.
Old Dec 19, 2002 | 10:04 AM
Quik Chris's Avatar
No, you don't get the head 'bored' the machine shop just has to move the dowel pins, plain and simple. The head has to be tapped and an oil line run from that to a NPST "T" fitting which goes where the oil sending unit is on the block. If you use a GS-R head, you really need a GS-R manifold, all the other B-series won't bolt up.
Remember the rule of three:
Fast
Cheap
Reliable
You can only choose two, the remaining other will be the consiquence.
tray3rd
11
Jun 3, 2004 12:58 PM
I3ackfire
Mar 8, 2004 12:49 PM
flyrice
Nov 1, 2003 02:19 PM
gribbs
Apr 11, 2003 02:53 PM
MXPX
Aug 29, 2001 08:22 AM
