ls/vtec
Old Apr 20, 2009 | 08:10 PM
lskid98's Avatar
Default ls/vtec
i have a couple of concerns about the ls/vtec i am planning to do and i want to find out about them before i tear into car. first is will the ls injectors work? Also if the stock ls pistons will clear the head? also having nothing to do with the conversion there is a creeking noise coming from my right front wheel only starting in first and reverse what might it be?
Old Apr 20, 2009 | 08:17 PM
90IntegraTuner's Avatar
Default Re: ls/vtec
The creeking sound you hear, yeah probably the wheel bearing...buddy has the same problem...get louder when you drive?
As for the injectors...they will work...most b series if not all carry the 240cc injectors
LS pistons will clear the the head...its not any smaller
Old Apr 20, 2009 | 08:48 PM
tonyle789's Avatar
Default Re: ls/vtec
i have a question if i have a ls block and a b16 head do i need to do and mods to the block or does it just bolts right on please help
Old Apr 20, 2009 | 08:58 PM
lskid98's Avatar
Default Re: ls/vtec
thanks i was also told that the creeking may be the half shaft.
Old Apr 20, 2009 | 09:06 PM
chillz03's Avatar
Default Re: ls/vtec
you need to get a kit that moves the Dowels for the back to front
http://shopping.lightningmotorsports...?productid=381
is web site has eveyting and tells you how to do it
Old Apr 20, 2009 | 09:59 PM
tonyle789's Avatar
Default Re: ls/vtec
thanks what the bore size for a 96 integra 4 door ls sorry im new to this
Old Apr 21, 2009 | 07:50 AM
HondaTom87's Avatar
Default Re: ls/vtec
81 mm all b series are 81 except for the b20
Old May 1, 2009 | 03:14 PM
jordan_GC's Avatar
Default Re: ls/vtec
i put head and everything back on for a friend and he put the rest back together, he said he isnt getting anything for it when he tries to start it, any sensors or what not need to be unplugged or sometihng that i should check out?
Old May 1, 2009 | 03:19 PM
jdm_bones's Avatar
Default Re: ls/vtec
What? Speak english!
Old May 1, 2009 | 04:52 PM
yunghov's Avatar
Default Re: ls/vtec
u also want to do gsr or si water pumps and timing belts and timing tension
Tong.Y
Dec 7, 2009 10:02 PM
ek4ferrio
Oct 6, 2006 10:14 PM
hondacura4life
Sep 9, 2006 12:19 PM
97teggLS
Jun 1, 2004 08:20 AM
xstalkrx
May 17, 2003 03:56 AM
