Ls Vtec
From: Good luck to this industry, you're gonna need it.
search man...
geez, all it takes is a little effort...
in all fairness though...if it's a b series head yes...
will you convert to OBDII...no. It IS OBDIIb if it's from a 99-00 Si
you will need to make it comply with OBDI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boris »</TD></TR><TR><TD CLASS="quote">So all ill have to do is run a rpm switch to the vtec solinoid</TD></TR></TABLE>
no.
You need larger fuel pump, 255.
You need to run an oil line to the block and tap the oil pan.
You need to get an ECU and chip it for vtec and low redline (stock block)
and more.
no.
and more.
black_integra
Jul 26, 2006 11:35 AM
