ls valvetrain
Old Jan 30, 2005 | 07:57 PM
the DA in HONDA's Avatar
Default ls valvetrain
i am putting together a 96 ls motor with some gsr pistons and all new gaskets, rings, rod bearing, crower cams(not much lift) and arp head bolts. i am wanting to get my ecu reflashed so i could hit a little high rpms and i was wondering what is a safe rev for the motor without stretching the rodbolts and ruining the valvetrain
Old Jan 30, 2005 | 08:17 PM
importdude2000's Avatar
7400 is absolute max i would go on a ls~
stock valvetrain
also factor in when the cams stop making power
its useless to rev to 10k rpm if the car stops making power at 7k
Old Jan 30, 2005 | 08:53 PM
Default Re: (importdude2000)
the cams stop making power at like 8 i have heard, they are used cams. they have been in a all motor ls
Modified by the DA in HONDA at 7:01 PM 1/31/2005
Old Jan 30, 2005 | 10:32 PM
lsvtec90's Avatar
Default Re: ls valvetrain (the DA in HONDA)
before i went to lsv i got 404s w/springs on and i take it to 8
Old Jan 31, 2005 | 06:02 PM
Default Re: ls valvetrain (lsvtec90)
anyone else got a thought on this, would it be reliable to take to 7400 every once in a while...bump bump
Old Jan 31, 2005 | 07:22 PM
boosted k20's Avatar
why would u get GSR pistons? those wont raise the compression ratio up too much. Get B16 pistons (PR3) or jdm B16 (P30) pistons for better compression.
Im run n crower 403's with crower springs and retainers. redline is at 7200 right now. will shift it up to 7500 after i put in my ARP rod bolts and P30 pistons. go n to the dyno after this to see where these cams stop making power. i dyno'd my car a month ago with the stock 6800 rev limit and the cams were still make n power.
do u have springs and reatiners (or just springs), then i would rev it to about 7200-7400 is u have springs. if u get arp rod bolts, then u can rev to high 7's or wherever these cams stop make n power.
if u have stock valve springs then i wouldnt raise the stock rev limit more than a few hundred rpms (about 200).
lriver0001
Apr 13, 2011 09:20 PM
maxpower98
May 1, 2009 08:26 AM
ls_bitik
May 27, 2007 11:56 AM
91ls-v
May 27, 2005 01:39 PM
yellaboi
Nov 18, 2003 07:51 AM
