Ls V-Tec question??
Old Mar 10, 2012 | 01:00 PM
edgecpt09's Avatar
Default Ls V-Tec question??
In building my Ls vtec I noticed that the head gasket that came in
My NPR itr engine kit constricts some ports on my b16 head. Is this
Normal or do I jaw the wrong head gasket?? Thanks guys!!
Old Mar 10, 2012 | 01:03 PM
Whiteboy99's Avatar
Default Re: Ls V-Tec question??
ur suppose to plug the holes...... did u buy a LSVtec kit?
Old Mar 10, 2012 | 01:15 PM
edgecpt09's Avatar
Yeah not that hole. Talking about the port holes in the head gasket itself constricting maybe 3 ports on the head by about 1/3.
Old Mar 10, 2012 | 02:15 PM
DirtyDA9's Avatar
It will still flow normaly. No worries. The oil galley's and water jackets are not constructed completely the same between LS and VTEC heads, so theres gonna be a little shape difference, but as long as it's not constricting a lot of the jacket, it's fine.
Old Mar 10, 2012 | 04:09 PM
edgecpt09's Avatar
Thx man that's what I thought. It's not much just wanted to be sure I hate doing things twice. Preciate ya!
Old Mar 14, 2012 | 08:39 PM
1ls/vtec's Avatar
Golden Eagle makes the proper gasket for the LSV swap. I got the full Golden Eagle LSV swap with ARP head studs for $300 about 5 years ago and is still running strong
Old Mar 14, 2012 | 08:40 PM
1ls/vtec's Avatar
LSV conversion kit, sorry
Old Mar 14, 2012 | 09:54 PM
sebTeggy's Avatar
Really? They make a custom head gasket? ^
Good info if true. You can get away with either a b16 or ls headgasket. You will here differences everywhere, but as long as they are facing up, you are good
Old Mar 14, 2012 | 10:00 PM
1ls/vtec's Avatar
Their head gasket isn't custom, sorry. If I recall right they said it is a OEM gasket from Honda and I believe it is a VTEC gasket. Like I said it was 5 years ago. I could be wrong. Just something to look in to.
Old Mar 14, 2012 | 10:07 PM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
Cometic makes a custom LS VTEC head gasket...they've made them for a long while now and are highly trusted.
Old Mar 14, 2012 | 10:10 PM
usdm420's Avatar
Community Builder
Here ya go:
http://www.ebay.com/itm/C4237-030-CO...c11900&vxp=mtr
Old Mar 18, 2012 | 07:52 PM
NaturalLS-V's Avatar
I just did a Ls-v build on my teggy about a month ago. The only difference in the ls head gasket to the b16/18 are the guide pin holes you have to drill out. I decided to go with the ls head gasket, but you can use either. There's no going around the fact that you have to drill the holes for the guide pins. So if you have a b16 gasket already use it.
Also, I made a Ls-v kit from gearheads. They sell oil sandwich plates and the steal breaded lines. In all, I think I spent around 150 In materials over the 300 for a golden eagle kit. I know most people have to have the name brand **** but if you're doing a budget build like I was it saves the pocket a nice chunk of change.
Old Mar 20, 2012 | 10:56 AM
GRIM516's Avatar
nice savings over the golden eagle kit. tht means more $ for the
Old Mar 23, 2012 | 01:51 PM
1ls/vtec's Avatar
U don't have to drill out anything. There are VTEC dowel pins that step down to fit from block to head. Like I said, the Gilden Eagle kit is a complete swap kit
Old Mar 23, 2012 | 03:05 PM
oldskoolda1's Avatar
I didn't drill mine
Jtuned DC2
Sep 27, 2007 08:17 PM
blk90teg
Feb 14, 2007 08:53 PM
civicswap
Jun 4, 2005 06:44 PM
migo
Sep 27, 2002 06:38 PM
tysir
Aug 20, 2001 07:27 PM
