Ls needs some lovin
Old Jun 17, 2003 | 06:34 PM
Tegracer95's Avatar
Default Ls needs some lovin
I have a 95 ls and i wanted to swap a type r but if the type-r motor is obd2, how hard is it to wire a obd1 harness into a obd2 harness???
Old Jun 17, 2003 | 06:54 PM
93hybrid's Avatar
Default Re: Ls needs some lovin (Tegracer95)
bizzump for a good guy somebody help a brother out.
Old Jun 17, 2003 | 06:58 PM
g2 GS-Argh's Avatar
Is there a reason you specifically want a B18C5? I only ask because you could build a poor-man's ITR cheaper, and probably not worry about OBD incompatibility.
Old Jun 17, 2003 | 06:59 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Ls needs some lovin (g2 GS-Argh)
get an OBD2>OBD1 harness adapter
Tegracer95's Avatar
poor mans itr? sorry if im a noob but how would i go about building that. would i just get a gsr and swap the parts?
Old Jun 17, 2003 | 07:45 PM
sPaRk'iT's Avatar
i said use the money on a turbo setup instead of swapping a type R.
Old Jun 17, 2003 | 08:12 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tegracer95 &raquo;</TD></TR><TR><TD CLASS="quote">poor mans itr? sorry if im a noob but how would i go about building that. would i just get a gsr and swap the parts?</TD></TR></TABLE>
a poormans type R = ls/vtec..
Old Jun 18, 2003 | 01:30 PM
g2 GS-Argh's Avatar
Default Re: Ls needs some lovin (N T R Z R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N T R Z R &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Not exactly. A real poor man's ITR would use a B18C1 for the superior oiling system (as compared to an LS). So essentially, just mate a cheap B16A head to a B18C1 block, upgrading internals as you see fit. Can be made to be more powerful than an ITR for cheaper.
Old Jun 18, 2003 | 06:32 PM
MooreBoost's Avatar
Default Re: Ls needs some lovin (sPaRk'iT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk'iT &raquo;</TD></TR><TR><TD CLASS="quote">i said use the money on a turbo setup instead of swapping a type R. </TD></TR></TABLE>
Id do that too, for sure.
gmoore
Old Jun 18, 2003 | 07:13 PM
DC4_95's Avatar
i'm in the same situation as you as I am planning an a R engine in the future. I've searched around and asked around too, and they say a OBD2 /OBD1 harness will do. People will say go turbo, ls/vtec, and the sugested poorman's type-r, which are good sugestions if you want to really build the engine from inside out.
If I ever get my R engine it will probably be mostly stock aside from the common bolt-ons. I will not turbo it nor will I build it up internally. Just want to have the high-end B engine .
Also If you want the integra-r transmission , they come with type-r swaps available. (of course u can buy it seperately , but its hard to find one by its self at a good price)
i just visited the http://www.jdmhondaparts.com and they have use full information about this at their FAQ in the Engine Packages section. ( i have no experience with this seller though)
Modified by DC4_95 at 5:42 AM 6/19/2003
eg6civic1538
Apr 30, 2007 06:51 PM
B20FERIO
Sep 8, 2006 11:05 AM
2k1_ITR_0736
Jun 16, 2003 11:00 AM
743power
Apr 7, 2003 10:39 AM
