LS ENGINE PROBLEMS...need help asap
Old Jan 6, 2006 | 11:43 AM
Louis53123's Avatar
Default LS ENGINE PROBLEMS...need help asap
i got a stock 93 teg..... my car will idle and drive fine for around a half hour...then after the car warms up for a lil itll bogg and hick-up in any gear but ussually when i shift into like 3rd it happens...this forces the rpms down and even when i slamm the gas to the floor the rpms dont go up and the car just gets slower and slower till it stalls........now i replaced the gas filter...and spark plugs which showed very positive results for about 15 mins...then the same problem occured...i took off my backseats to check the gas tank out and when i open the sensor capsule there was rust colored stuff all lined in the tank...now im pretty sure its rust, but i alsoknow that the car was sitting for 2 years so it could eather be rust from condesation, or sand from the gas sitting there so long...do you guys thinks its rust or sand? im ******* confused and need to get my car back on the road...i need it!
Old Jan 6, 2006 | 11:51 AM
Ninety3 Integra's Avatar
The car was sitting for 2 years? Drain the tank and put some fresh gas in and try that first.
Old Jan 6, 2006 | 11:53 AM
Louis53123's Avatar
Default Re: (Ninety3 Integra)
i did....and i even put dry gas when i drained it....ive tried almost everything.....with my knowladge im gonna ******* kill someone hhaha
Old Jan 6, 2006 | 12:02 PM
Louis53123's Avatar
Default Re: (Louis53123)
does nayone think i should drop the gas tank and clean it? i feel like thats a bad idea but i know impurities in the fuel cause problems like this....
Old Jan 6, 2006 | 12:05 PM
shorto85's Avatar
When gasoline sits for a long time it turns into varnish... definitely drain your tank
Old Jan 6, 2006 | 12:11 PM
Louis53123's Avatar
Default Re: (shorto85)
i drained it already.....like i said 2 posts ago......in addition i put dry gas in when i drained it......im asking should i drop the tank...i just now took the two straps off....im ready to drop it but not 100percent sure if i should CLEAN THE INSIDE of the gas tank....because that could expletive up the flow of the engine...AHHH....help me
Old Jan 6, 2006 | 12:25 PM
b_serious's Avatar
get the injectors cleaned too
Old Jan 6, 2006 | 02:07 PM
jman86's Avatar
Default Re: (b_serious)
And get a new fuel filter...Can never be too safe.. I would suggest just get one of those 3 stage cleaner systems, that cleans the injectors the Throttle body and its a fuel treatment...just my .02
JMAN
Old Jan 11, 2006 | 09:05 AM
Louis53123's Avatar
Default Re: LS ENGINE PROBLEMS...need help asap (Louis53123)
so i drained my tank for the 2nd time...this time putting octane booster as well as a fuel system cleaner and filled the tank up with 93 instead of 87....i started up the car late at night when i finished and let it idle for around 2 hours...reving it every 10 or so minutes.....in the morning i drove it from 9 till 5 at night....0 problems..and i was happy....luckily as i was going up my driveway it started loosing power and stalled again....now i had to ride the clutch to get it up my driveway and it kept stalling and not gaining any rpms like before....then the ext morning i tried starting it again and itll start and stall right away....im thinking a piece of depree or someshit from my tank got lodged in an injector? im not sure and im about to buy a new engine...i just got the money...someone please help me before i go waste my money...should i phsically scrub the tank out...it still had a layer of depree/rust or varnish or sand im not sure what it is THANX
KraziCivicSi
Jun 30, 2008 05:27 AM
N-Sol
Apr 3, 2008 09:40 AM
dthug
12
Dec 18, 2006 02:08 PM
gourley
Aug 14, 2006 08:45 AM
eg6turb0
Jan 10, 2005 11:44 AM
